I am attempting to run a nested for loop to clip habitat types by Marine Protected Area (MPA) region offshore California. When running the code below I receive error 000732 (red text). Any help is greatly appreciated.
File "C:\Python27\ArcGIS10.3\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 326, in RunScript
exec codeObject in __main__.__dict__
File "E:\BlueCarbon\GIS\Script\MPARegionClip.py", line 19, in <module>
arcpy.Clip_analysis(fc, reg, op_FC)
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\analysis.py", line 56, in Clip
raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Clip Features: Dataset CentralCoastProj.shp does not exist or is not supported
Failed to execute (Clip).
CODE:
import arcpy
from arcpy import env
#Set Variables
hab_Workspace = "E:\\BlueCarbon\\GIS\\Workspace\\habproj "
regWorkspace = "E:\\BlueCarbon\\GIS\\Workspace\\IndRegProj\\"
tWorkspace = "E:\\BlueCarbon\\GIS\\Workspace\\habproj_regions"
env.workspace = regWorkspace
region = arcpy.ListFeatureClasses("")
env.workspace = hab_Workspace
FClist = arcpy.ListFeatureClasses("")
print FClist
for fc in FClist:
for reg in region:
op_FC = tWorkspace + "\\" + fc + reg
