db_map_dbms_to_sde_type::Error in converting Oracle type = 188 db_describe_select::Error converting column 8 db_map_dbms_to_sde_type::Error in converting Oracle type = 23 db_describe_select::Error converting column 9 db_map_dbms_to_sde_type::Error in converting Oracle type = 8 db_describe_select::Error converting column 12 db_map_dbms_to_sde_type::Error in converting Oracle type = 8 db_describe_select::Error converting column 3 db_map_dbms_to_sde_type::Error in converting Oracle type = 188 db_describe_select::Error converting column 6 db_map_dbms_to_sde_type::Error in converting Oracle type = 23 db_describe_select::Error converting column 3 db_map_dbms_to_sde_type::Error in converting Oracle type = 187 db_describe_select::Error converting column 4 db_map_dbms_to_sde_type::Error in converting Oracle type = 23 db_describe_select::Error converting column 58 db_map_dbms_to_sde_type::Error in converting Oracle type = 190 db_describe_select::Error converting column 2
8 = SQLT_LNG /* long */ 23 = SQLT_BIN /* binary data(DTYBIN) */ 187 = SQLT_TIMESTAMP /* TIMESTAMP */ 188 = SQLT_TIMESTAMP_TZ /* TIMESTAMP WITH TIME ZONE */ 190 = SQLT_INTERVAL_DS /* INTERVAL DAY TO SECOND */
