I am trying to build a Python Toolbox, like in the following code snippet. However I got error because of the last line (Filter) . I have to filter the files because without the filter the output window shows all kind of data including Feature class.
<SPAN class="comment token"># First parameter </SPAN>
param1 <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Parameter<SPAN class="punctuation token">(</SPAN>
displayName<SPAN class="operator token">=</SPAN><SPAN class="string token">"Output Raster Dataset"</SPAN><SPAN class="punctuation token">,</SPAN>
name<SPAN class="operator token">=</SPAN><SPAN class="string token">"in_rasterdataset"</SPAN><SPAN class="punctuation token">,</SPAN>
datatype<SPAN class="operator token">=</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Raster Dataset"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
parameterType<SPAN class="operator token">=</SPAN><SPAN class="string token">"Required"</SPAN><SPAN class="punctuation token">,</SPAN>
direction<SPAN class="operator token">=</SPAN><SPAN class="string token">"Output "</SPAN><SPAN class="punctuation token">)</SPAN>
param1 <SPAN class="punctuation token">.</SPAN>filter<SPAN class="punctuation token">.</SPAN>list <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Raster"</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
