I have 2 portal installed on 2 different servers.
and i need an operations dashboard on my laptop that i can use for both portals.
I am working offline.
I run the utility file, i copied the extracted folder to the first portal, and the operations dashboard is working fine.
But now i am not able to change the portal URL from the sign in, it is always connected to portal 1.
what should i do to use the same operations dashboard with both portals?
I am using portal for ArcGIS 10.5
thank u
