Can you use a Unique Value Renderer function for a MapImageLayer sublayer?
When I try using an existing field name as a string it works, but when I try to set up a function like in the api documentation I get the error:
[esri.renderers.UniqueValueRenderer] .field: cannot write field to JSON since it's not a string value
The code I am using:
function test(feature){
var renderer = {
type: "unique-value", // autocasts as new UniqueValueRenderer()
field: test,
Is there a way to make it work?
