I am new to Python, and am trying to write a script that would upload a geodatabase to AGOL at a scheduled interval. However, the 32 bit distribution of Python cannot handle the file size (over 1 MB), even when the multipart parameter of addItem is set to true. Through some investigation, I've learned that this is a limitation of Python32, and to do what I'd like to do I need the 64 bit version. I was trying to avoid having multiple installs of Python (as I said, I'm new to it, so the less complication, the better), but if I remove Python as it was installed with ArcGIS, I lose Arcpy, which I also need. So, my question is, does anyone know of a solution to this issue, or am I stuck dealing with multiple Python installs?
EDIT: I should have mentioned, I'm using the ArcREST site package for my upload.
