My code loops through layers in multiple projects and prints the highest values for a specific field. I want to then append those values to an empty dictionary, but when I try and print the dictionary at the end of the code it is still empty.
I've been trying to figure this out for a couple days now, but can't seem to figure it out myself or find a solution online.
Any help or suggestions would be greatly appreciated. Thanks.
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">from</SPAN> arcpy <SPAN class="keyword token">import</SPAN> env
markets <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">3000</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token">### Declare variables</SPAN>
fc <SPAN class="operator token">=</SPAN> <SPAN class="string token">'OpenCenters'</SPAN>
fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'USER_market_id'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'USER_ID'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'USER_Center_Name'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'USER_Opening_Date'</SPAN><SPAN class="punctuation token">]</SPAN>
fieldname <SPAN class="operator token">=</SPAN> <SPAN class="string token">'USER_market_id'</SPAN>
sqlclause <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>None<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Order By USER_market_id, USER_ID'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> market <SPAN class="keyword token">in</SPAN> markets<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>market<SPAN class="punctuation token">)</SPAN>
results_dict <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN>
env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"E:\arcGIS_Shared\Python\HeatMaps_{0}\HeatMaps_{0}.gdb"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>market<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">## Define WHERE clause statement</SPAN>
whereclause <SPAN class="operator token">=</SPAN> <SPAN class="string token">"""{} = """</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>AddFieldDelimiters<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> fieldname<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> str<SPAN class="punctuation token">(</SPAN>market<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">### Cursor to create list of centers to loop through</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>in_table <SPAN class="operator token">=</SPAN> fc<SPAN class="punctuation token">,</SPAN> field_names <SPAN class="operator token">=</SPAN> fields<SPAN class="punctuation token">,</SPAN> where_clause<SPAN class="operator token">=</SPAN>whereclause<SPAN class="punctuation token">,</SPAN> sql_clause<SPAN class="operator token">=</SPAN>sqlclause<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">###Loop to run SummarizeWithin by center</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> <SPAN class="punctuation token">(</SPAN>cursor<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
p <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mp<SPAN class="punctuation token">.</SPAN>ArcGISProject<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">'E:\arcGIS_Shared\Python\HeatMaps_{0}\DiscreteHeatMaps{0}_{1}.aprx'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>market<SPAN class="punctuation token">,</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
m <SPAN class="operator token">=</SPAN> p<SPAN class="punctuation token">.</SPAN>listMaps<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
Layers <SPAN class="operator token">=</SPAN> m<SPAN class="punctuation token">.</SPAN>listLayers<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"DiscreteVisitsSumWithin{0}_{1}*"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>market<SPAN class="punctuation token">,</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SUM_USER_VisitCount'</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">for</SPAN> Layer <SPAN class="keyword token">in</SPAN> Layers<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN>
sqlClause <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>None<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ORDER BY '</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">'SUM_USER_VisitCount'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>in_table <SPAN class="operator token">=</SPAN> Layer<SPAN class="punctuation token">,</SPAN> field_names <SPAN class="operator token">=</SPAN> fields<SPAN class="punctuation token">,</SPAN>
sql_clause <SPAN class="operator token">=</SPAN> sqlClause<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> searchCursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>max<SPAN class="punctuation token">(</SPAN>searchCursor<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
results_dict<SPAN class="punctuation token">[</SPAN>Layer<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> max<SPAN class="punctuation token">(</SPAN>searchCursor<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">except</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">pass</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>results_dict<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
