I have 5 point feature classes that I am trying to append into a point feature class. I get the following error when I attempt to run the code shown below:
Failed to execute. Parameters are not valid.
ERROR 000338: Inputs must be either all Feature Classes, Tables or Rasters; not mixed.
Failed to execute (Append).
I can run the append successfully when using the Append tool in Desktop. I am at a loss as to why the code throws the error. Any insight would be very much appreciated.
# Import arcpy module
import arcpy
import os
SDE = r'C:\Development\py1\gis@GISDEV02 frt (emadb51 DC) - VegD2.sde'
# Set local variables
FC_Inven = os.path.join(SDE, 'GIS.VegD_Inventory')
FC_Unit = os.path.join(SDE, 'GIS.VegD_Unit_Inventory')
FC_Hrly2 = os.path.join(SDE, 'GIS.VegD_Hourly_Inventory')
FC_Hrly = os.path.join(SDE, 'GIS.VegD_Hourly')
FC_Flat = os.path.join(SDE, 'GIS.VegD_FlatRate')
FC_Matrix = os.path.join(SDE, 'GIS.VegD_Matrix')
schemaType = "NO_TEST"
fieldMappings = ""
subtype = ""
try:
# Process: Truncate Table
arcpy.TruncateTable_management(FC_Inven)
# Process: Append the feature classes into the empty feature class
arcpy.Append_management('FC_Unit; FC_Hrly2; FC_Hrly; FC_Flat; FC_Matrix', FC_Inven, schemaType, fieldMappings, subtype)
except Exception as err:
print(err.args[0])
