I am facing a strange behavior using Java script API 4.0. I have two layers to display, one is a tile layer and the other one is a feature layer. When I add the tile layer at the bottom, then I can't zoom in to all levels, but when I add the tile layer at the top every thing goes well but of curse the feature layer will not be visible.
Below is the code that cause the problem:
var MyFeatureLayer = new FeatureLayer({ url: "http://*******/MapServer"});var MyTileLayer = new TileLayer({ url: "http://*******/MapServer"});
var map = new Map({
layers: [MyTileLayer, MyFeatureLayer]
If I changes the order when adding the layers it works, but the tile layer will hide the feature layer:
var map = new Map({
layers: [MyFeatureLayer, MyTileLayer]
Any Idea?
