Hi guys,
I'm trying to use Add data widget in Web App Builder for GIS but when I upload a .CSV file it show this error "Analyze Service error: Unexpected: no hosting server available". And I don't know how to fix it .Could some one help me on that ?
regards,
Nasser
Are you using AGOL or Portal for ArcGIS? If Portal for ArcGIS, I found one thread about configuration of ports and installation of the Data Store being not properly configured can cause this error.
Hi Robert,
Thank you for your respond.
I'm using Portal for ArcGIS . Could you please give more clarification on that !
Hi Nasser,
Are you using Web AppBuilder for ArcGIS (WAB) embedded within Portal for ArcGIS or WAB Developer Edition?
What release of Portal for ArcGIS are you using?
This was a known bug in earlier releases of Portal for ArcGIS, but I believe was fixed in the 10.6 release. However, there have been some hot fixes released related to this issue. If you're using a Portal for ArcGIS release later than 10.6, I suggest you contact esri Tech Support to investigate further.
Hope this helps,
