import arcpy mxd = arcpy.mapping.MapDocument(r"C:\path\to\my.mxd") for lyr in arcpy.mapping.ListLayers(mxd): if lyr.description == "Layer Name": lyr.showLabels = True del mxd arcpy.RefreshTOC() arcpy.RefreshActiveView()
mxd = arcpy.mapping.MapDocument('current')
If you want to see the result of scripts run in the Python Window in ArcMap reflected in the current map, reference the map document like this:mxd = arcpy.mapping.MapDocument('current')That should do what you want.
import arcpy ... mxd = arcpy.mapping.MapDocument("CURRENT") ... layer = arcpy.mapping.ListLayers(mxd, "")[0] ... if layer.supports("LABELCLASSES"): ... for lblclass in layer.labelClasses: ... lblclass.showClassLabels = True ... lblclass.expression = " [PARCELID]" ... layer.showLabels = True ... arcpy.RefreshActiveView()
