I've got a series of MXDs with definition queries with file gdb-specific syntax. I'd like to batch modify those DQs to work with enterprise gdb syntax. Not every layer has a DQ, and not all DQs are the same. The problem I'm running into is with the expressions portion... the function is passing 'SHAPE.STLength()' with the quotes to the definition query, which doesn't match the syntax (need it without the quotes). Changing them to double quotes returns similar results, and removing the quotes all together causes the function to fail.
Any ideas?
import arcpy
from arcpy import env
from os import path
env.workspace = ws = r"C:\temp\DefQueryScript\test1"
expressions = {
'shape_length' : 'SHAPE.STLength()',
'shape_area' : 'SHAPE.STArea()',
'SHAPE_Length' : 'SHAPE.STLength()',
'SHAPE_Area' : 'SHAPE.STArea()',
'SHAPE_length' : 'SHAPE.STLength()',
'SHAPE_area' : 'SHAPE.STArea()',
def letsGetThisPartyStarted():
''' For each Map Document in the workspace, check each layer for a
definition query, and if found, update it according to the contents of
the expression dictionary.'''
print "Let's get this party started!\n"
mxds = getMXDs()
for i, mxd in enumerate(mxds):
for layer in getLayers(mxd):
evaluateExpression(layer)
saveMXD(mxd, i)
def getMXDs():
''' Create a list of each Map Document in the workspace(s).'''
mxds = [arcpy.mapping.MapDocument(m) for m in arcpy.ListFiles("*.mxd")]
return mxds
def getLayers(mxd):
''' Collects all feature layer in a Map Document.'''
print "{0} layers:\n".format(mxd.filePath)
layers = [l for l in arcpy.mapping.ListLayers(mxd) if l.isFeatureLayer]
return layers
def evaluateExpression(lyr):
''' If the layer has a Definition Query, update that query using the
dictionary of expressions.'''
if lyr.definitionQuery:
for exp in expressions.items():
key, value = exp[0], exp[1]
if key in lyr.definitionQuery:
updateDefinitionQuery(lyr, key, value)
else:
print " {0}: No Definition Query found\n".format(lyr.name)
pass
def updateDefinitionQuery(lyr, old_exp, new_exp):
''' Replaces the old expression with the new one. Fill in the old/new
associations in the "expressions" dictionary above.'''
print " {0}:".format(lyr.name)
print " Old expression: {0}".format(lyr.definitionQuery)
lyr.definitionQuery = lyr.definitionQuery.replace(old_exp, new_exp)
print " New expression: {0}\n".format(lyr.definitionQuery)
def saveMXD(mxd, i):
''' Saves a copy of the Map Document which has had it's layers Definition
Queries updated.'''
mxd.saveACopy(path.join(ws, "COPY_" + mxd.filePath + "_{0}.mxd".format(i)))
del mxd
if __name__ == "__main__":
print "'fin.'"
