I tried to follow the "Search for an address" tutorial, but it gave the error "A / libc: Fatal signal 11 (SIGSEGV), code 1 (SEGV_MAPERR)" when using "arcgis-android: 100.9.0". I spent half a day looking for the cause and found out that using version "arcgis-android: 100.4.0" everything works.Can you tell me how to debug the cause of such errors?To reproduce this error, you can use my repository in which there are two commits with different versions of arcgis-android.Commits · redballtoy/ArcGisSearchForAddress · GitHub
Hi Dmitry,
can you tell us your Android devices and SDK versions please? Also, do you have a full stack trace from this error? I'm guessing this happens when you try to dispay the result (that is displaySearchResult()). Does it happen when you simply use the API to search for an address and don't display the result, in queryLocator()?
Gayle
Dmitry, if you could try the equivalent sample and let us know if that works for you, we'd appreciate it.
Find address | ArcGIS for Developers
Gayle.
I'm having the same issue when trying the starter app tutorial.
Device: Android emulator, with Android 10.0 (API 29) x86 target.
compileSdkVersion(30)buildToolsVersion("30.0.2")
Arcgis runtime versions with the issue: 100.8.0 and 100.9.0
Using version 100.7.0 seems to fix the issue. Also, the issue only occurs when using vector base maps(e.g. Basemap.Type.STREETS_VECTOR). Using regular base maps(Basemap.Type.STREETS) does work.
Stacktrace:
Hope this helps.
Best,
Erik
I am having the exact same issue after upgrading device version to Android 10.
compileSdkVersion 30buildToolsVersion "30.0.3"
implementation 'com.esri.arcgisruntime:arcgis-android:100.10.0'
Especially after querying the inventory, I am encountering this error when trying to click on the listed inventory and navigate to its location.
Mostly it gives the, Fatal signal 6 (SIGABRT), code -1 error. After giving this error a few times, it gives this error;
A/libc: Fatal signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x47333ba615fdfc in tid 29108 (RTC thread).
I would bi appreciated if anyone can help to solve this issue.
