Hello everyone!!!
I am kind of new on JavaScript. I have been looking for a way to make an editable layer from GeoRSS feed. Because of the format, I can't change symbology or enable popup info from GeoRSS feed so I'm guessing that if I make a layer, I will be able to do it. I'm trying to do it by PictureMarkerSymbol and rendering but I don't know how to make the script work. I don't know if the symbology problem would be solved by rendering or making a layer or something like that and nor do I know if the situation with the popup could be solved by other java constructors ... Can a beautiful and kind soul help me, please?
This is my code:
<html>
<head>
<meta name="description" content="DevLab: Style a feature layer">
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>ArcGIS JavaScript Tutorials: Style a feature layer</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.13/esri/css/main.css">
<script src="https://js.arcgis.com/4.13/"></script>
</head>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/GeoRSSLayer",
"esri/symbols/PictureMarkerSymbol"
function(
Map,
MapView,
GeoRSSLayer,
PictureMarkerSymbol
var map = new Map({
basemap: "streets-night-vector"
var view = new MapView({
container: "viewDiv",
map: map,
center: [-99.433823, 19.613484],
zoom: 9
// Create the layer
var WazeLayer = new GeoRSSLayer({
url: "URL from GeoRSS sorry I can not provide it..."
// Add the layer
map.add(WazeLayer);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
Thank you so so so much
