Trying to create a Token at my initial login page.
I think I may have some syntax error but cant figure out where....ANY ideas?
Imports System.Data.SqlClient
Imports System.Net.Mail
Imports System.Data
Imports System.IO
Imports System.Web.Configuration
Imports System.Web.UI
Imports System.Net
Partial Class Login
Inherits System.Web.UI.Page
Public username As String = ""
Public password As String = ""
Protected Sub LoginButton_Click(sender As Object, e As EventArgs)
username = Login1.UserName
password = Login1.Password
Session("username") = username
Session("password") = password
Dim sConn As String
sConn = System.Configuration.ConfigurationManager.ConnectionStrings("SQLConnection").ToString
Dim sqlConn As New SqlConnection(sConn)
Dim sqlcomm As New SqlCommand("select * from users_test where username='" & username & "'and password ='" & password & "'", sqlConn)
sqlcomm.CommandType = Data.CommandType.Text
Dim rdrloginexists As SqlDataReader
sqlConn.Open()
rdrloginexists = sqlcomm.ExecuteReader
Dim myDT As DataTable = New DataTable
myDT.Load(rdrloginexists)
sqlConn.Close()
Create_Token(username, password, "123456")
End Sub
Public Sub Create_Token(ByVal username As String, ByVal password As String, ByVal clientid As String)
Dim referer As String = "http://ourServer.gov/login.aspx"
Dim expiration = "2014"
Dim tokenUrl As String = "https:/http://ourServer.gov/login.aspx/Create_Token?username=" & username & "&password=" & password & "&referer=" & referer & "&expiration=" & expiration & "&f=json"
Dim tokenRequest = DirectCast(WebRequest.Create(tokenUrl), HttpWebRequest)
tokenRequest.Referer = referer
Dim token1 = tokenRequest.GetResponse()
Using stream As Stream = token1.GetResponseStream()
Dim reader As New StreamReader(stream, Encoding.UTF8)
Dim responseString As [String] = reader.ReadToEnd()
End Using
End Sub
End Class
