Sub MultipatchInfo() Dim pDoc As IMxDocument Dim pMap As IMap Set pDoc = ThisDocument Set pMap = pDoc.FocusMap Dim pPolygon As IPolygon Dim pMultiPatch As IMultiPatch '-- Get the selected layer Dim pFLayer As IFeatureLayer Set pFLayer = pDoc.SelectedLayer Dim pFc As IFeatureClass Set pFc = pFLayer.FeatureClass '-- Loop through the features and get the area Dim pFCursor As IFeatureCursor Set pFCursor = pFLayer.Search(Nothing, False) Dim pFeat As IFeature Set pFeat = pFCursor.NextFeature Dim multiPatchGeometryCollection As IGeometryCollection Set multiPatchGeometryCollection = New MultiPatch Dim strType As String Dim strRingType As String Do Until pFeat Is Nothing If pFeat.Shape.GeometryType = esriGeometryMultiPatch Then Set multiPatchGeometryCollection = pFeat.ShapeCopy UserForm1.ListBox1.AddItem pFeat.OID & "-----------" & multiPatchGeometryCollection.GeometryCount 'MsgBox ("Yes:" & multiPatchGeometryCollection.GeometryCount) Dim pMP As IMultiPatch2 Set pMP = New MultiPatch Set pMP = multiPatchGeometryCollection For i = 0 To multiPatchGeometryCollection.GeometryCount - 1 Select Case multiPatchGeometryCollection.Geometry(i).GeometryType Case 11 strType = "Ring" Case 18 strType = "TriangleStrip" Case 19 strType = "TriangleFan" Case 22 strType = "Triangles" End Select Select Case pMP.GetRingType(multiPatchGeometryCollection.Geometry(i), True) Case 1 strRingType = "esriMultiPatchInvalidRing" Case 2 strRingType = "esriMultiPatchUndefinedRing" Case 4 strRingType = "esriMultiPatchFirstRing" Case 8 strRingType = "esriMultiPatchRing" Case 16 strRingType = "esriMultiPatchOuterRing" Case 32 strRingType = "esriMultiPatchInnerRing" Case 28 strRingType = "esriMultiPatchBeginningRingMask" Case 40 strRingType = "esriMultiPatchFollowingRingMask" Case 3 strRingType = "esriMultiPatchProblemCaseRingMask" End Select UserForm1.ListBox2.AddItem strType & "---" & i & "---" & strRingType Next i End If Set pFeat = pFCursor.NextFeature Loop UserForm1.Show End Sub
I am parsing a multipatch file ,representing 3d buildings using the following VBA script.Though multipatch is a collection of rings,trainglefans,triaglestrips and triangles,I am getting onyl "Rings" for all buildings.Consequently ,my rendering in OpenGL or any other external graphics library is showing correct result in wireframe mode.Since ,the output is only "Rings" type,I am unable to fill the buildings polygons.Attachment has sampe multipatch file,Snapshots of redndered image.Can anyone point out what went wrong...Sub MultipatchInfo() Dim pDoc As IMxDocument Dim pMap As IMap Set pDoc = ThisDocument Set pMap = pDoc.FocusMap Dim pPolygon As IPolygon Dim pMultiPatch As IMultiPatch '-- Get the selected layer Dim pFLayer As IFeatureLayer Set pFLayer = pDoc.SelectedLayer Dim pFc As IFeatureClass Set pFc = pFLayer.FeatureClass '-- Loop through the features and get the area Dim pFCursor As IFeatureCursor Set pFCursor = pFLayer.Search(Nothing, False) Dim pFeat As IFeature Set pFeat = pFCursor.NextFeature Dim multiPatchGeometryCollection As IGeometryCollection Set multiPatchGeometryCollection = New MultiPatch Dim strType As String Dim strRingType As String Do Until pFeat Is Nothing If pFeat.Shape.GeometryType = esriGeometryMultiPatch Then Set multiPatchGeometryCollection = pFeat.ShapeCopy UserForm1.ListBox1.AddItem pFeat.OID & "-----------" & multiPatchGeometryCollection.GeometryCount 'MsgBox ("Yes:" & multiPatchGeometryCollection.GeometryCount) Dim pMP As IMultiPatch2 Set pMP = New MultiPatch Set pMP = multiPatchGeometryCollection For i = 0 To multiPatchGeometryCollection.GeometryCount - 1 Select Case multiPatchGeometryCollection.Geometry(i).GeometryType Case 11 strType = "Ring" Case 18 strType = "TriangleStrip" Case 19 strType = "TriangleFan" Case 22 strType = "Triangles" End Select Select Case pMP.GetRingType(multiPatchGeometryCollection.Geometry(i), True) Case 1 strRingType = "esriMultiPatchInvalidRing" Case 2 strRingType = "esriMultiPatchUndefinedRing" Case 4 strRingType = "esriMultiPatchFirstRing" Case 8 strRingType = "esriMultiPatchRing" Case 16 strRingType = "esriMultiPatchOuterRing" Case 32 strRingType = "esriMultiPatchInnerRing" Case 28 strRingType = "esriMultiPatchBeginningRingMask" Case 40 strRingType = "esriMultiPatchFollowingRingMask" Case 3 strRingType = "esriMultiPatchProblemCaseRingMask" End Select UserForm1.ListBox2.AddItem strType & "---" & i & "---" & strRingType Next i End If Set pFeat = pFCursor.NextFeature Loop UserForm1.Show End Sub
