I have a custom script tool that is supposed to set up a map layout, by adjusting the scale bar, north arrow, title, and legend. It is then supposed to reference a bookmark and export the layout as a PDF.
The problem is that when I use this tool in ModelBuilder it references the wrong bookmarks.
I'm using this script tool in ModelBuilder for ArcGIS Pro. This model iterates through Urgent Care centers and its corresponding data one at a time (in alphabetical order by center name). I have bookmarks for every Urgent Care center, so my thought is that, if I can find a way for the model to reference the bookmarks in alphabetical order, then they will correspond with the correct Urgent Care center.
Could this be achieved via a table or list Index, or some kind of loop? Or is there a better way to go about this whole process?
Here is the code from the script tool I am using.
import arcpy
input layer
lyr = arcpy.GetParameterAsText(0)
input name of layout
p = arcpy.mp.ArcGISProject("CURRENT")
lyt = p.listLayouts("Layout_King")[0]Reposition the scale bar
scaleBar = lyt.listElements("MAPSURROUND_ELEMENT", "Scale Bar")[0]
mf = scaleBar.mapFrame
scaleBar.elementPositionX = mf.elementPositionX + 0.0
scaleBar.elementPositionY = mf.elementPositionY - 0.5Reposition the north arrow
northArrow = lyt.listElements("MAPSURROUND_ELEMENT", "North Arrow")[0]
mf = northArrow.mapFrame
northArrow.elementPositionX = mf.elementPositionX + 8.8
northArrow.elementPositionY = mf.elementPositionY + 0.7Align the title with the center of the map frame
title = lyt.listElements("TEXT_ELEMENT","Name of Map Text")[0]
mf = lyt.listElements('MAPFRAME_ELEMENT',"Map Frame")[0]
title.elementPositionX = mf.elementPositionX + (mf.elementWidth / 3.7)
title.elementPositionY = mf.elementPositionY + (mf.elementHeight / 0.98)Reposition the Legend and fix legend title
legend = lyt.listElements("LEGEND_ELEMENT", "Legend")[0]
legend.title = "Legend"
legend.elementPositionX = mf.elementPositionX + 7.7
legend.elementPositionY = mf.elementPositionY + 7.15setting layout to bookmark
aprx = arcpy.mp.ArcGISProject("Current")add name of layout
lyt = aprx.listLayouts("Layout_King")[0] mf = lyt.listElements("MAPFRAME_ELEMENT")[0]add name of bookmark
bkmks = mf.map.listBookmarks("*")
for bkmk in bkmks:
mf.zoomToBookmark(bkmk)
lyt.exportToPDF(r"C:\arcGIS_Shared\Exports" + "\\" + bkmk.name + ".pdf")
