Sub JoinedFields() Dim pDoc As IMxDocument Set pDoc = ThisDocument Dim pFeatureLayer As IFeatureLayer Set pFeatureLayer = pDoc.FocusMap.Layer(0) Dim pFeat As IFeature Set pFeat = pFeatureLayer.FeatureClass.GetFeature(12) Dim pTable As ITable Dim pDisplayTable As IDisplayTable Set pDisplayTable = pFeatureLayer Set pTable = pDisplayTable.DisplayTable Dim pFields As IFields Dim pField As IField Set pFields = pTable.Fields For i = 0 To pFields.FieldCount - 1 Debug.Print pFields.Field(i).Name Next End Sub
I think if you give nothing as the queryfilter to ISelectionSet.Search, it will return all the records as a cursor.
I tried your code with a file geodatabase and it requried the fully qualified table name and field name, so the behavior is not limited to an SDE geodatabase. But whatever works.
Since your line features are not part of the code you have written and all your code accesses currently is the point feature class, you do not need the emedded loops to read the joined table. You also will not need embedded loops if you are going to simply construct one line from the points, since you would then just be writing to one feature and you can access all of the fields you need including the shape field of the parent table from the ICursor object derived from the IDisplayTable. However, if you are going to construct more than one line from a set of points based on some attrribute you would then need a set of embedded loops to control the creation of each line feature and the writing of the point attribute.
I have revised your code to make it more efficient. Your code is slow because it uses repeated queries inside of a loop (it also was repeatedly doing a Dim of the Row variable inside the loop as well, which is a big no no. Never do a Dim inside of a loop).
My join table is a standalone SQL table in a non-SDE database. I've found that if I join to a table within an SDE database then I have to use fully qualified table/field names, but not if to a non-SDE table.What I've got is a tool (in .Net) that loops through selected points, creates a line from each point, and then takes some attributes from that point and writes it to the line. The join is on the point feature class, and I am wanting to take a value from the join table and put it on the line. Mike.
I tried your code and don't understand why it works for you at all. When I used it on a joined feature layer I got errors when I tried to just use a field name in the join table. I had to use the fully qualified table name and field name to obtain the display table field index and a correctly formatted query where clause inside of the loop to access the joined field name. I could not just use an unqualified field name as you seem to be doing.
I am assuming you intend to write data to the parent feature class and not just read the data of the joined table. Otherwise, if all you wanted to do was read data you should be able to just use the display table without having to use the parent feature class and a pair of embedded loops on the parent feature class and on the display table. To just read data you should bypass the FeatureSelection and just set the SelectionSet to the DisplaySelectionSet of the display table and loop through it to get your key and joined field together (using the fully qualified table name and field name of the joined table). So what is this code really supposed to end up doing for you? If you need to use it to write to the parent table (or you actually have a 1:M or M:M relationship), then the embedded loops are probably necessary.
Take a look at the IGeoFeatureLayer interface for another method to get at the values on joined fields (IGeoFeatureLayer.SearchDisplayFeatures). It might be an easier approach.
Public Sub GetLayerSelection2() Dim pMxDoc As IMxDocument Set pMxDoc = ThisDocument Dim pFLayer As IFeatureLayer Set pFLayer = pMxDoc.FocusMap.Layer(0) 'Get first layer Dim pDisplayTable As IDisplayTable Set pDisplayTable = pFLayer If Not TypeOf pDisplayTable.DisplayTable Is IRelQueryTable Then MsgBox "Feature Layer is not joined! Exiting Sub." Exit Sub End If Dim pSelSet As ISelectionSet Set pSelSet = pDisplayTable.DisplaySelectionSet Dim pCount As Long ' Use Integer only if this is VB.Net and not VBA. pCount = pSelSet.Count If pCount > 5 Then MsgBox "Too many features selected. Please select 5 or less." 'Was quite slow, but now probably no longer necessary Exit Sub End If Dim pTableCursor As ICursor pSelSet.Search Nothing, True, pTableCursor Dim pRow As IRow Set pRow = pTableCursor.NextRow Dim pFSel As IFeatureSelection Set pFSel = pFLayer Dim pSelSet2 As ISelectionSet Set pSelSet2 = pFSel.SelectionSet Dim pFCursor As IFeatureCursor pSelSet2.Search Nothing, True, pFCursor Dim pFeature As IFeature Set pFeature = pFCursor.NextFeature Dim pTableIndex As Long pTableIndex = pDisplayTable.DisplayTable.Fields.FindField("ParentTableName.OBJECTID") ' Substitute the actual ParentTableName or use JoinTableName.FieldName If pTableIndex = -1 Then MsgBox "ParentTableName.OBJECTID Field Not Found! Exiting Sub." ' Substitute the appropriate message. Exit Sub End If Dim pFeatureIndex As Long pFeatureIndex = pFeature.Fields.FindField("OBJECTID") If pFeatureIndex = -1 Then MsgBox "OBJECTID Field Not Found! Exiting Sub." Exit Sub End If Do Until pFeature Is Nothing ' Keep your loop as tight as possible and do not do Dim statements inside of it. Debug.Print pFeature.Value(pFeatureIndex) & " = " & pRow.Value(pTableIndex) ' report value of field in join table Set pRow = pTableCursor.NextRow Set pFeature = pFCursor.NextFeature Loop End Sub
Dim pTableIndex As Long pTableIndex = pTable.Fields.FindField("SERVSTAT") ' Field to be found in join table If pTableIndex = -1 Then msgbox "SERVSTAT field not found. Exiting Sub." Exit Sub End If Dim pFeatureIndex As Long pFeatureIndex = pFeature.Fields.FindField("COMPKEY") If pFeatureIndex = -1 Then msgbox "COMPKEY field not found. Exiting Sub." Exit Sub End If Do Until pFeature Is Nothing strQuery = "COMPKEY = " & pFeature.Value(pFeatureIndex) 'Use join field (COMPKEY) to find matching record in table pQFilter.WhereClause = strQuery Set pTableCursor = pTable.Search(pQFilter, False) Dim pRow As IRow Set pRow = pTableCursor.NextRow Do Until pRow Is Nothing Debug.Print pRow.Value(pTableIndex) ' report value of field in join table Set pRow = pTableCursor.NextRow Loop Set pFeature = pFCursor.NextFeature Loop
Public Sub GetLayerSelection2() Dim pMxDoc As IMxDocument Set pMxDoc = ThisDocument Dim pFLayer As IFeatureLayer Set pFLayer = pMxDoc.FocusMap.Layer(0) 'Get first layer Dim pFSel As IFeatureSelection Set pFSel = pFLayer Dim pSelSet As ISelectionSet Set pSelSet = pFSel.SelectionSet Dim pFCursor As IFeatureCursor pSelSet.Search Nothing, True, pFCursor Dim pCount As Integer pCount = pSelSet.count If pCount > 5 Then MsgBox "Too many features selected. Please select 5 or less." 'Is quite slow, so don't run if lots of features Exit Sub End If Dim pFeature As IFeature Set pFeature = pFCursor.NextFeature Dim pDisplayTable As IDisplayTable Set pDisplayTable = pFLayer Dim pTable As ITable Set pTable = pDisplayTable.DisplayTable Dim strQuery As String Dim pQFilter As IQueryFilter Set pQFilter = New QueryFilter Dim pTableCursor As ICursor Dim pTableIndex As Long pTableIndex = -1 Dim pFeatureIndex As Long pFeatureIndex = -1 Do Until pFeature Is Nothing If pFeatureIndex = -1 Then pFeatureIndex = pFeature.Fields.FindField("COMPKEY") End If strQuery = "COMPKEY = " & pFeature.Value(pFeatureIndex) 'Use join field (COMPKEY) to find matching record in table pQFilter.WhereClause = strQuery Set pTableCursor = pTable.Search(pQFilter, False) Dim pRow As IRow Set pRow = pTableCursor.NextRow If pTableIndex = -1 Then pTableIndex = pTable.Fields.FindField("SERVSTAT") ' Field to be found in join table End If Do Until pRow Is Nothing Debug.Print pRow.Value(pTableIndex) ' report value of field in join table Set pRow = pTableCursor.NextRow Loop Set pFeature = pFCursor.NextFeature Loop End Sub
Just a note to improve performance on a portion of the code Jeff provided. Make it a practice to get the index of any field outside of the loops you create and directly use the field index in the loop. The FindField operation does a schema search loop that really only needs to be done once outside of your loop. Repeating loops within loops drags down performance. Using the index value directly inside the loop acts like direct array access to the field and does not cause a secondary hidden loop to occur for every record your loop processes. (From best practices with cursors training at the ESRI conference). So the sample code should be revised as follows: Dim pTableCursor As ICursor Dim pRow As IRow Set pTableCursor = pTable.Search(Nothing, True) Set pRow = pTableCursor.NextRow Dim fIndex as Long fIndex = pTable.Fields.FindField("FeatureClass.FieldName") 'fully qualified field name from joined table Do Until pRow Is Nothing Debug.Print pRow.Value(fIndex) ' removes a hidden loop required to find the field Set pRow = pTableCursor.NextRow Loop Hope this helps.
Public Sub GetLayerSelection() 'allows enumeration through all features selected from a particular layer 'to get all features regardless of what layer they are in, use IMap.SelectedFeatures Dim mxDoc As IMxDocument Set mxDoc = ThisDocument Dim fLayer As IFeatureLayer Set fLayer = mxDoc.SelectedLayer Dim fSel As IFeatureSelection Set fSel = fLayer Dim ss As ISelectionSet Set ss = fSel.SelectionSet Dim fCur As IFeatureCursor ss.Search Nothing, True, fCur Dim feat As IFeature Set feat = fCur.NextFeature Do Until feat Is Nothing Debug.Print feat.OID Set feat = fCur.NextFeature Loop End Sub
Dim pTableCursor As ICursor Dim pRow As IRow Set pTableCursor = pTable.Search(Nothing, True) Set pRow = pTableCursor.NextRow Do Until pRow Is Nothing Debug.Print pRow.Value(pTable.Fields.FindField("FeatureClass.FieldName")) 'fully qualified field name from joined table Set pRow = pTableCursor.NextRow Loop End Sub
Sub JoinedFields() Dim pDoc As IMxDocument Set pDoc = ThisDocument Dim pFeatureLayer As IFeatureLayer Set pFeatureLayer = pDoc.FocusMap.Layer(0) Dim pFeat As IFeature Set pFeat = pFeatureLayer.FeatureClass.GetFeature(12) Dim pTable As ITable Dim pDisplayTable As IDisplayTable Set pDisplayTable = pFeatureLayer Set pTable = pDisplayTable.DisplayTable 'Dim pFields As IFields 'Dim pField As IField 'Set pFields = pTable.Fields 'For i = 0 To pFields.fieldCount - 1 ' Debug.Print pFields.Field(i).Name 'Next Dim pTableCursor As ICursor Dim pRow As IRow Set pTableCursor = pTable.Search(Nothing, True) Set pRow = pTableCursor.NextRow Do Until pRow Is Nothing Debug.Print pRow.Value(pTable.Fields.FindField("FeatureClass.FieldName")) 'fully qualified field name from joined table Set pRow = pTableCursor.NextRow Loop End Sub
For i = 0 To pDisplayTable.DisplayTable.Fields.FieldCount - 1Debug.Print(pDisplayTable.DisplayTable.Fields.Field(i).Name)Next
