Hello all,
Here's my problem. We have a point layer in Collector which is currently in use.
The customer gave us a list of accessories attached to a point layer. We proceeded to the creation of a relational table between the points and a table. Everything is working. The point ID is linked to the table and inspections can take place. Where we have a problem is when a new point is created. All these new points have the same ID and the relationship is no longer made.All new entry has the same value.
Can I use the calculate method in this field? Can it be automatically concatenated with the objectID? Other solutions to create a random ID on the same field used to create the relationship?
Need to find a solution... it's start to be a very long process manually.
Thank you.
Cheers!
