I have a implemented Collector for ArcGIS and the feature service I have created is over 2Gb with all the photo attachments. I cannot seem to download the FGDB as I normally did when the file size was less than 2Gb. Does anyone have this issue and the download scripts that are availale dont seem to work. Is there a restriction on the size of the Feature Service in ArcGIS Online?
Hi Eoghan,
Have you tried the following tool:
https://community.esri.com/docs/DOC-6496-download-arcgis-online-feature-service-or-arcgis-server-featuremap-service
HI,
Yes I have tried it and it has does not work anymore.
It worked until the size of the FGDB exceeded 2Gb.
Regards,
Eoghan
A File Geodatabase should have no limit, but a Personal Geodatabase will have a limit of 2 GBs. Can you share the service to a Group in ArcGIS Online and invite my user account (jskinner_CountySandbox)? I can take a look at the service.
Recently I had some problems downloading the result of a field inspection with a little over 7000 points and photo attachments The size of the FGDB was rather large (> 3GB) and if I remember correctly for that reason it did not allow me to download it. I ended up creating a replica through REST and download the replica instead: ArcGIS REST API
Thanks Xander Bakker
You shouldn't be running into issues downloading a feature service over 2gb. I would suggest contacting technical support to look into this further. The workaround for creating a replica should also work, here is a technical article outlining the steps.
How To: Retrieve attachments from a hosted feature service
Let us know if this gets you up and running.
-Kelly
