Hello everyone!
I have a problem with querying related data.
I've created a Mobile Map Package (mmpk) with twolayers.
One layer has lines segments and the other the vertex of those lines
The table of the segments layer has the ids of his vertex.
| OBJECTID | F_ID_NODE | T_ID_NODE | SHAPE |
| 1 | 100 | 101 | PolyLine |
And the the table of vertex has some atrributes like type:
| OBJECTID | ID_NODE | TYPE | SHAPE |
| 1 | 100 | 1 | POINT |
| 2 | 101 | 2 | POINT |
And i've created 2 relationship classes
Here is the relashionship class properties:
| Relationship Class | vertex_segments_f_rel |
| Type | Simple |
| Cardinality | One to one |
| Notification | None |
| Origin Name | vertex |
| Origin Primary Key | ID_NODE |
| Origin Foreign Key | F_ID_NODE |
| Destination Name | segments |
| Forward Path Label | sefementsf |
| Backward Path Label | vertexf |
| Relationship Class | vertex_segments_t_rel |
| Type | Simple |
| Origin Foreign Key | T_ID_NODE |
| Forward Path Label | sefementst |
| Backward Path Label | vertext |
When i try to retrieve the related features with the SDK i have next error:
Exception occurred: com.esri.arcgisruntime.ArcGISRuntimeException: Item not found in the database. (Table, domain, relationship class, etc.)
I used the same patern listed here :
https://github.com/Esri/arcgis-runtime-samples-android/tree/master/list-related-features
The thing is. When i use only one relationship it works.
Maybe I'm missing something.,Its posible to do that or is a bug?
In ArcGis Pro the relations works as expected
An idea?
SDK Version : 100.1.0
Thanks!!
