class ToolValidator: """Class for validating a tool's parameter values and controlling the behavior of the tool's dialog.""" def __init__(self): """Setup arcpy and the list of tool parameters.""" import arcpy self.params = arcpy.GetParameterInfo() def initializeParameters(self): """Refine the properties of a tool's parameters. This method is called when the tool is opened.""" if self.params[1].value == "Use Existing Intersect": self.params[9].parameterDependencies = [2] elif self.params[1].value == "Build New Intersect": self.params[9].parameterDependencies = [4] return def updateParameters(self): """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parameter has been changed.""" if self.params[1].value == "Use Existing Intersect": self.params[2].enabled = True self.params[3].enabled = False self.params[4].enabled = False self.params[5].enabled = False elif self.params[1].value == "Build New Intersect": self.params[2].enabled = False self.params[3].enabled = True self.params[4].enabled = True self.params[5].enabled = True else: self.params[2].enabled = False self.params[3].enabled = False self.params[4].enabled = False self.params[5].enabled = False
class ToolValidator: """Class for validating a tool's parameter values and controlling the behavior of the tool's dialog.""" def __init__(self): """Setup arcpy and the list of tool parameters.""" import arcpy self.params = arcpy.GetParameterInfo() def initializeParameters(self): """Refine the properties of a tool's parameters. This method is called when the tool is opened.""" self.params[4].filter.type = "ValueList" self.params[6].filter.type = "ValueList" self.params[8].filter.type = "ValueList" return def updateParameters(self): """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parameter has been changed.""" # Define function that returns field values for a fc parameter (par) to the field parameter (field); # i.e. changeFilter(2,4) takes the fields from (2) and returns them as a list to (4) def changeFilter(par,field): if self.params[par].value: list = [] fc = arcpy.Describe(self.params[par].value) for x in fc.fields: list.append(x.name) self.params[field].filter.list = list #if self.params[1].altered = True: if self.params[1].value == "Use Existing Intersect": self.params[4].filter.list = [] self.params[6].filter.list = [] self.params[8].filter.list = [] changeFilter(2,4) changeFilter(2,6) changeFilter(2,8) self.params[2].enabled = True self.params[3].enabled = False self.params[5].enabled = False self.params[7].enabled = False elif self.params[1].value == "Build New Intersect": self.params[4].filter.list = [] self.params[6].filter.list = [] self.params[8].filter.list = [] changeFilter(3,4) changeFilter(5,6) changeFilter(7,8) self.params[2].enabled = False self.params[3].enabled = True self.params[5].enabled = True self.params[7].enabled = True else: self.params[2].enabled = False self.params[3].enabled = False self.params[5].enabled = False self.params[7].enabled = False def updateMessages(self): """Modify the messages created by internal validation for each tool parameter. This method is called after internal validation.""" return
