hi all, I'm using Javascript 4.1 for the first time and just trying create a very basic web scene with my own image service overlain on the default world elevation layer. The world elevation layer shows up fine but my own image service (added as an ImageryLayer) isn't visible. I get an error "ERR_CONNECTION_RESET" for the ImageryLayer url line of code. Apparently for some reason it can't access the service. But it was accessible and visible from the Javascript viewer on the REST page. Wondering if it might be a problem with my coding (below). Thanks!
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/views/SceneView"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/ImageryLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/on"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/dom"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/domReady!"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>Map<SPAN class="punctuation token">,</SPAN> SceneView<SPAN class="punctuation token">,</SPAN> ImageryLayer<SPAN class="punctuation token">,</SPAN> on<SPAN class="punctuation token">,</SPAN> dom<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// Create inundation layer and add to the map</SPAN>
<SPAN class="keyword token">var</SPAN> floodLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ImageryLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fmobjack.vims.edu%2Farcgis%2Frest%2Fservices%2FVIMS_CCRM%2FPoquoson_3D_Test%2FImageServer" target="_blank">http://mobjack.vims.edu/arcgis/rest/services/VIMS_CCRM/Poquoson_3D_Test/ImageServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Create the Map</SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"topo"</SPAN><SPAN class="punctuation token">,</SPAN>
ground<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"world-elevation"</SPAN><SPAN class="punctuation token">,</SPAN>
layers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>floodLayer<SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token">// Create the MapView</SPAN>
<SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SceneView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
camera<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
position<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">76.407</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">37.149</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1346</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
heading<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">300</SPAN><SPAN class="punctuation token">,</SPAN>
tilt<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">60</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
