Hello -
The world elevation service does not provide enough topographic relief in my gently sloping project area. I am trying to test if it gets better using a USGS NED raster in a custom ElevationLayer. However, in the browser console log I receive "Error Decoding: undefined" for my custom DEM tiles.
The only thing different from this sample and the documentation is that I do not have the Image Server extension on our ArcGIS Server (10.5). I'm simply publishing an Image Service from Catalog to our regular Server. The REST URL however does state "Image Server". The raster is in Web Mercator and tiled with ArcGIS tile scheme.
Can I only do this with a literal Image Server license? Or am I missing something else? I cannot share my dem URL.
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/views/SceneView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/BaseElevationLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/ElevationLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/renderers/SimpleRenderer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/ObjectSymbol3DLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/PointSymbol3D"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>Map<SPAN class="punctuation token">,</SPAN> SceneView<SPAN class="punctuation token">,</SPAN> BaseElevationLayer<SPAN class="punctuation token">,</SPAN> ElevationLayer<SPAN class="punctuation token">,</SPAN> FeatureLayer<SPAN class="punctuation token">,</SPAN> SimpleRenderer<SPAN class="punctuation token">,</SPAN> ObjectSymbol3DLayer<SPAN class="punctuation token">,</SPAN> PointSymbol3D<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> mapObj <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
basemap <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"satellite"</SPAN><SPAN class="punctuation token">,</SPAN>
ground <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"world-elevation"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> viewObj <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SceneView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
container <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"mapDiv"</SPAN><SPAN class="punctuation token">,</SPAN>
camera<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
position<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
x<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">10888242.6</SPAN><SPAN class="punctuation token">,</SPAN>
y<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">6093694.16</SPAN><SPAN class="punctuation token">,</SPAN>
z<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1618269</SPAN><SPAN class="punctuation token">,</SPAN>
spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">102100</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
heading<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">17</SPAN><SPAN class="punctuation token">,</SPAN>
tilt<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">48</SPAN>
map <SPAN class="punctuation token">:</SPAN> mapObj<SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// Reference to the map object created before the scene</SPAN>
scale <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">50000</SPAN><SPAN class="punctuation token">,</SPAN>
center <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">97.81</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">47.94</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token">// Create elevation layer and add to the map</SPAN>
<SPAN class="keyword token">var</SPAN> dem <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ElevationLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fxxx%2Farcgis%2Frest%2Fservices%2Fdem%2FImageServer" target="_blank">https://xyz/arcgis/rest/services/dem/ImageServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">//ArcGIS Server 10.5</SPAN>
visible<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN>
mapObj<SPAN class="punctuation token">.</SPAN>ground<SPAN class="punctuation token">.</SPAN>layers<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>dem<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
