I have a rather complicated enterprise geodatabase version scheme that looks like this:
Periodically I get updates to our data inventory, and I would like to update all the versions together. I tried the append_management command as follows:
<SPAN class="comment token"># some code</SPAN>
<SPAN class="keyword token">for</SPAN> fds <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListDatasets<SPAN class="punctuation token">(</SPAN><SPAN class="string token">''</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'feature'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">''</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> fc <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFeatureClasses<SPAN class="punctuation token">(</SPAN><SPAN class="string token">''</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">''</SPAN><SPAN class="punctuation token">,</SPAN>fds<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
inputPath <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace<SPAN class="punctuation token">,</SPAN> fds<SPAN class="punctuation token">,</SPAN> fc<SPAN class="punctuation token">)</SPAN>
outputPath <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>outLocation<SPAN class="punctuation token">,</SPAN> sdeString <SPAN class="operator token">+</SPAN> fc<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Append_management<SPAN class="punctuation token">(</SPAN>inputPath<SPAN class="punctuation token">,</SPAN> outputPath<SPAN class="punctuation token">,</SPAN> schemaType<SPAN class="punctuation token">,</SPAN> fieldMappings<SPAN class="punctuation token">,</SPAN> subtype<SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
However, this only updated the DEFAULT SDE version. What's the best strategy to push those changes to the child versions as well? I would like to be able to do this programatically.
Thanks, Naci
