So i am working on a app which i am trying to use the Tab theme but the logo is super small, so i tired making it larger and i had some success but it's not correct. I added the following, which mad it bigger but squished. See attached pic.
Not sure what i am missing, i tired playing with the height and width in the sytles.css but i can't get it symmetric round.
I made changes to the WebAppBuilderForArcGIS\server\apps\8\themes\TabTheme\styles\default\style.css.
<SPAN class="punctuation token">.</SPAN>claro <SPAN class="punctuation token">.</SPAN>jimu<SPAN class="operator token">-</SPAN>widget<SPAN class="operator token">-</SPAN>header <SPAN class="punctuation token">.</SPAN>logo <SPAN class="punctuation token">{</SPAN>
height<SPAN class="punctuation token">:</SPAN> 90px !important<SPAN class="punctuation token">;</SPAN>
width<SPAN class="punctuation token">:</SPAN> 90px<SPAN class="punctuation token">;</SPAN>
min<SPAN class="operator token">-</SPAN>width<SPAN class="punctuation token">:</SPAN> 50px<SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token">-</SPAN>webkit<SPAN class="operator token">-</SPAN>border<SPAN class="operator token">-</SPAN>radius<SPAN class="punctuation token">:</SPAN> 50px<SPAN class="punctuation token">;</SPAN>
border<SPAN class="operator token">-</SPAN>radius<SPAN class="punctuation token">:</SPAN> 40px !important<SPAN class="punctuation token">;</SPAN>
position<SPAN class="punctuation token">:</SPAN> relative<SPAN class="punctuation token">;</SPAN>
top<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN>0px !important<SPAN class="punctuation token">;</SPAN>
left<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN>3px !important<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">.</SPAN>claro <SPAN class="punctuation token">.</SPAN>jimu<SPAN class="operator token">-</SPAN>widget<SPAN class="operator token">-</SPAN>header <SPAN class="punctuation token">.</SPAN>logo img <SPAN class="punctuation token">{</SPAN>
max<SPAN class="operator token">-</SPAN>height<SPAN class="punctuation token">:</SPAN> 90px<SPAN class="punctuation token">;</SPAN>
margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN> auto<SPAN class="punctuation token">;</SPAN>
display<SPAN class="punctuation token">:</SPAN> block<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I made changes to WebAppBuilder2.7\WebAppBuilderForArcGIS\server\apps\8\config.json.
Changed line 8 to 70.
<SPAN class="string token">"widgetOnScreen"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"widgets"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"uri"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"themes/TabTheme/widgets/Header/Widget"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"position"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"left"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"top"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"right"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"height"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">70</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"relativeTo"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"browser"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Changed line 4 to 70
<SPAN class="string token">"uri"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"themes/TabTheme/widgets/SidebarController/Widget"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"top"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">70</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"bottom"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">24</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"relativeTo"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"browser"</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
