HI All, I have my map placed within a div <div id="mapContainer"> <div id="mapDiv" dojotype="dijit.layout.ContentPane" region="center" style="height:100%; width:100%"></div> </div>
The mapContainer is itself within a jQuery ui tab widget. The map re sizes itself when browser size is changed without any extra code in FF however in IE8, the map does not resize itself.I have tried various suggestions including one from the guidelines but nothing seems to work. Any ideas?dojo.connect(dojo.byId('mapDiv'), 'resize', function(extent) { map.resize(); });Moving the map div under the body tag and not within any widget or any other tags fixes the issue, but i do want to use the tab widget.Thanks
