John Gravois and Tom Wayson - i would greatly appreciate some guidance when working on Cedar charts. I am trying to update the axes on a JSON chart in our Hub app. The chart is type Bar and draws as desired, except that there is no Y-axis label and the X-axis labels are draw at a -45 angle. I want to add the Y-axis label and have the x-axis labels displayed at 90 degrees.
I have followed the examples describe at this esri link in the JSON specification section and the examples at ember-cli-cedar, but i cant seem to change either the content of the Y-axis label or the rotation of the x-axis labels.
Based on the esri docs, i have added the content below to the 'bar' chart example at ember-cli-cedar:
"overrides": {
"legend": {
"enabled": true
"backgroundColor": "#E6E6FA",
"backgroundAlpha": 1,
"categoryAxis": {
"labelRotation": -90
the background color changes and the legend appears, but the axis label does not rotate. I have tried the following code in both the ember-cli-cedar playground (nested in the 'overrides' and as a standalone element) and the amCharts CodePen. It works in the CodePen but not in the cedar playground.
"xAxes": [{
"type": "CategoryAxis",
"dataFields": {
"category": "country"
"renderer": {
"labels": {
"rotation": -90,
"verticalCenter": "middle",
"horizontalCenter": "left"
I've tried similar things with setting the Y-axis label but have had the same general luck - doesn't work in Cedar; works in amCharts Code Pen. Any thoughts on how to change the contents of the Y-Axis label and the rotation of the x-axis labels?
Thank you
