2011-05-03 07:05:51.416000 | Create SDE Connection file and export SDE Features to Shapefiles 2011-05-03 07:06:00.709000 | SDE Connection created successfully 2011-05-03 07:06:00.709000 | SDE Connection file is ready 2011-05-03 07:06:00.709000 | Export SDE Nodes to shp 2011-05-03 07:06:00.709000 | Export SDE Pipes to shp 2011-05-03 07:08:33.498000 | Delete original locarc shapefile 2011-05-03 07:08:33.701000 | Rename new locarc shapefile to replace old shapefile 2011-05-03 07:08:34.029000 | Export SDE local lines to shp 2011-05-03 07:12:38.404000 | Create SDE Connection file and export SDE Features to Shapefiles 2011-05-03 07:12:46.118000 | SDE Connection created successfully 2011-05-03 07:12:46.118000 | SDE Connection file is ready 2011-05-03 07:12:46.118000 | Export SDE Nodes to shp 2011-05-03 07:12:46.118000 | Export SDE Pipes to shp 2011-05-03 07:12:46.118000 | Export SDE local lines to shp 2011-05-03 07:15:02.437000 | Delete original locnode shapefile 2011-05-03 07:15:02.593000 | Rename new locnode shapefile to replace old shapefile 2011-05-03 07:15:02.859000 | Export SDE local lines to shp 2011-05-03 07:15:02.859000 | Export of SDE to SHP completed successfully
I am having a similar issue in 10.3 release. When my block group data is joined to a tabular data set, the "feature class to feature class" and "Copy Features" tools in Model Builder take at least 10x as long to run compared to a manual Data-Export function. I understand 217k rows is a decent amount of data, but if the manual process takes less than 5 minutes, why would the model builder process take an hour? Also running into memory issues on some iterations. Anyone else experiencing this in later versions?
10.0 SP3Non-net featureclass: 17 min 30 sec Net featureclass: 51 min 10 sec10.0 SP1Non-net featureclass: 18 secNet featureclass: 22 sec
SP3 Exports:--Address FC, no geometric network, 29,088 points, 11/4/11Start Time: Fri Nov 04 13:49:30 2011Succeeded at Fri Nov 04 14:07:00 2011 (Elapsed Time: 17 minutes 30 seconds)--Ran through the progress bar twice - once really fast, then very slowly.--Sewer Service Connection FC, geometric network, 23,882 points, 11/4/11Start Time: Fri Nov 04 14:09:48 2011Succeeded at Fri Nov 04 15:00:58 2011 (Elapsed Time: 51 minutes 10 seconds)--Ran through progress bar at least five times.SP1 Exports:--Address FC, no geometric network, 29,088 points, 11/4/11Start Time: Fri Nov 04 19:33:55 2011Succeeded at Fri Nov 04 19:34:13 2011 (Elapsed Time: 18.00 seconds)--Ran through progress bar once, fast.--Sewer Service Connection FC, geometric network, 23,882 points, 11/4/11Start Time: Fri Nov 04 19:36:25 2011WARNING 000645: Output format does not support GlobalIDs. Field GlobalID will not be converted to output.Succeeded at Fri Nov 04 19:36:47 2011 (Elapsed Time: 22.00 seconds)--Ran through progress bar once.
For reference, I placed a counter on my script and left it running Friday night.The result2011-05-28 19:13:59.655000 | Total time to execute = 1 day, 4:24:41.896000Took over a day.I am going to request that we try to update another machine with SP2 to verify.I was kind of hoping others were having similar problems before we try to contact our ESRI Support.I've run the Fc to Fc tool on network and local shapefiles and they work just fine.When I run the tool against an SDE feature, it is really slow.If I monitor the statusbar %, it gets to 99%, then starts over again at 0% and seems to get stuck in a loop. Because I can cancel and it will finish without errors and the data seems to be intact.
