Hi ,
I have an wms server and i want to use this service's GetMap function via url get query. I done it and i get an picture/image result which png/geotiff/kml etc. type. But there is a problem with show this image on the map. Image has an its extend scale like in the attachment.
Query url like below :
http://giswebservices.massgis.state.ma.us/geoserver/wms
Is there any way show image with/without coordinates on the map ?
Thanks.
Yes. Here is a C++ sample demonstrating what you can do with WMS with the C++ API.
https://developers.arcgis.com/qt/cpp/sample-code/wms_layer_sample.htm
You can download the sample from https://developers.arcgis.com/qt/cpp/sample-code/
I hope this helps.
Hello. I would like to understand this issue better, so here are some questions. Some answers may seem obvious, but I want to understand clearly.
- Is the attached PNG file the actual file that was returned from the WMS service?
- If so, was this image returned from the service whose URL begins with cbsservis.tkgm.gov.tr/tkgm.ows/wms?
- Should the image only contain the Antalya province?
- Are you using the Runtime SDK for Qt C++ (Qt Widgets) API or the QML (Qt Quick) API?
- Can you share the part of the code that displays the image on the map?
Thank you.
Url which start with geonet is extra . There is misspelling.
1. Yes Png file type. But service support many image type like jpeg,tiff,geotiff. Also there are atom,kml etc
2.Yes
3.Yes
4. Mostly Qml. Actually we have developed with qml because of JS support and easy to use.
5.
Envelope {
xMin: 25.382409179687
yMin: 35.74005859375
xMax: 44.144582031249
yMax: 41.913056640624
spatialReference.wkid: 4326
Rectangle {
width: 1003
height: 400
Map {
transformOrigin: Item.Right
anchors.fill: parent
rotationByPinchingEnabled: true
magnifierOnPressAndHoldEnabled: true
mapPanningByMagnifierEnabled: true
focus:true
ArcGISDynamicMapServiceLayer{
url: "http://server.arcgisonline.com/arcgis/rest/services/ESRI_Imagery_World_2D/MapServer"
extent:sfExtent
// Create a flickable to view a large image.
Flickable {
anchors.fill:parent
contentWidth: picture.width
contentHeight: picture.height
Image {
source:"";
asynchronous: true
opacity: 0.8
states: State {
when: view.movingVertically || view.movingHorizontally
PropertyChanges { target: verticalScrollBar; opacity: 0.1 }
PropertyChanges { target: horizontalScrollBar; opacity: 0.1 }
transitions: Transition {
NumberAnimation { properties: "opacity"; duration: 400 }
ScrollBar {
width: 12; height: view.height-12
anchors.right: view.right
opacity: 0
orientation: Qt.Vertical
position: view.visibleArea.yPosition
pageSize: view.visibleArea.heightRatio
width: view.width-12; height: 12
anchors.bottom: view.bottom
orientation: Qt.Horizontal
position: view.visibleArea.xPosition
pageSize: view.visibleArea.widthRatio
And Final thank you
The source for the Image component gets a map as a PNG from the service. This is a raster image file. You can display it as an Image but you cannot add it as a Layer in the Map.
Hi Thomas,
thanks for reply
Is there any way show this image on the map with right place (with spatial reference)? I ask it to you because we develop an project with this services and other wfs services (for table queries) and showing this image or wms layer last part. I will be very plesant if i can do that with your help.
Regards.
