netcdf largeFillValue { // format variant: 64bit dimensions: x = 39393 ; y = 17766 ; variables: double x(x) ; double y(y) ; double z(x, y) ; z:_FillValue = 9.96920996838687e+036 ; }
I've found the problem. Z must be stored in row-major order, ie z(y, x), not z(x, y).The latter works, but is unusably slow especially with larger data sets (presumably once the size of z exceeds the cache).
Remember you are creating a layer and it may be subjected to the memory of your system. While you may have a lot of RAM to spare ArcMap is a 32 bit process in the foreground and at 10.1 background it is 64 bit. Can you indicate if the process fails due to memory? While I have never tried to create a NETCdf of that size, I would think that the limitations of a layer file on your system would be the issue.
