<slData:DataGrid.Columns> <slData:DataGridTextColumn CanUserSort="True" SortMemberPath="NAME" Binding="{Binding Attributes[NAME]}" Header="Abrev."/> <slData:DataGridTextColumn CanUserSort="True" SortMemberPath="MIN_NAME_E" Binding="{Binding Attributes[MIN_NAME_E]}" Header="Province Name"/> <slData:DataGridTextColumn CanUserSort="True" SortMemberPath="MIN_STATUS" Binding="{Binding Attributes[MIN_STATUS]}" Header="Status"/> </slData:DataGrid.Columns>
dgc.Binding = new System.Windows.Data.Binding("Attributes[NAME]");
<slData:DataGrid x:Name="QueryDetailsDataGrid" Grid.Row="1" Width="Auto" Height="120" AutoGenerateColumns="False" HeadersVisibility="Column" Background="White" IsReadOnly="True" HorizontalScrollBarVisibility="Hidden" RowStyle="{StaticResource MyCustomRow}" CanUserSortColumns="True" SelectionChanged="QueryDetailsDataGrid_SelectionChanged" LoadingRow="QueryDetailsDataGrid_LoadingRow"> <!--<slData:DataGrid.Columns> <slData:DataGridTextColumn CanUserSort="True" SortMemberPath="NAME" Binding="{Binding Attributes[NAME]}" Header="Abrev."/> <slData:DataGridTextColumn CanUserSort="True" SortMemberPath="MIN_NAME_E" Binding="{Binding Attributes[MIN_NAME_E]}" Header="Province Name"/> <slData:DataGridTextColumn CanUserSort="True" SortMemberPath="MIN_STATUS" Binding="{Binding Attributes[MIN_STATUS]}" Header="Status"/> </slData:DataGrid.Columns>--> </slData:DataGrid>
// Setup depending on selected layer switch (tbxLayerSelected.Text.ToString()) { case "Provinces": // Provinces is the 4th layer, index 3 queryTaskService = serverURL + "BaseMap/MapServer/3"; fieldsList = new string[] { "NAME", "MIN_NAME_E", "MIN_STATUS" }; QueryDetailsDataGrid.Columns.Clear(); DataGridTextColumn dgc = new DataGridTextColumn(); dgc.CanUserSort = true; dgc.SortMemberPath = "NAME"; dgc.Binding = new System.Windows.Data.Binding("Attribute[NAME]"); dgc.Header = "Abrev."; QueryDetailsDataGrid.Columns.Add(dgc); dgc = new DataGridTextColumn(); dgc.CanUserSort = true; dgc.SortMemberPath = "MIN_NAME_E"; dgc.Binding = new System.Windows.Data.Binding("Attribute[MIN_NAME_E]"); dgc.Header = "Province Name"; QueryDetailsDataGrid.Columns.Add(dgc); dgc = new DataGridTextColumn(); dgc.CanUserSort = true; dgc.SortMemberPath = "MIN_STATUS"; dgc.Binding = new System.Windows.Data.Binding("Attribute[MIN_STATUS]"); dgc.Header = "Status"; QueryDetailsDataGrid.Columns.Add(dgc); break; default: break; } //QueryTask queryTask = new QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/" + // "Demographics/ESRI_Census_USA/MapServer/5"); QueryTask queryTask = new QueryTask(queryTaskService); queryTask.ExecuteCompleted += QueryTask_ExecuteCompleted; queryTask.Failed += QueryTask_Failed; // Bind data grid to query results Binding resultFeaturesBinding = new Binding("LastResult.Features"); resultFeaturesBinding.Source = queryTask; QueryDetailsDataGrid.SetBinding(DataGrid.ItemsSourceProperty, resultFeaturesBinding); Query query = new ESRI.ArcGIS.Client.Tasks.Query(); // Specify fields to return from query //query.OutFields.AddRange(new string[] { "STATE_NAME", "SUB_REGION", "STATE_FIPS", "STATE_ABBR", "POP2000", "POP2007" }); query.OutFields.AddRange(fieldsList); query.Geometry = args.Geometry; // Return geometry with result features query.ReturnGeometry = true; queryTask.ExecuteAsync(query); } private void QueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args) { FeatureSet featureSet = args.FeatureSet; if (featureSet == null || featureSet.Features.Count < 1) { MessageBox.Show(msgNoFeatures); return; } GraphicsLayer graphicsLayer = Map.Layers["MySelectionGraphicsLayer"] as GraphicsLayer; if (featureSet != null && featureSet.Features.Count > 0) { QueryDetailsDataGrid.ItemsSource = args.FeatureSet.Features; foreach (Graphic feature in featureSet.Features) { feature.Symbol = LayoutRoot.Resources["ResultsFillSymbol"] as FillSymbol; graphicsLayer.Graphics.Insert(0, feature); } ResultsDisplay.Visibility = Visibility.Visible; } MyDrawSurface.IsEnabled = false; }
myGrid.ItemsSource = args.FeatureSet.Features;
MyGrid.Columns.Add(new DataGridTextColumn() { CanUserSort = true, SortMemberPath = "NAME", Binding = new System.Windows.Data.Binding("Attributes[NAME]"), Header = "Abrev." }); MyGrid.Columns.Add(new DataGridTextColumn() { .....
