Hi ArcGIS team,
I've added an Image (example: floor plan) by using PictureMarkerSymbol class; and add the graphic onto map by using GraphicOverlay class.
PictureMarkerSymbol pictureMarkerSymbol = new PictureMarkerSymbol(myImage);
Graphic graphic = new Graphic(polygon.getExtent().getCenter(), pictureMarkerSymbol);
pictureMarkerSymbol.loadAsync();
pictureMarkerSymbol.addDoneLoadingListener(new Runnable() {
@Override
public void run() {
mGraphicsOverlay.getGraphics().add(graphic);
});However, I am facing issue where the image loaded is fixed on its size and not dynamically resize when I zoom in or out of the map. For instance, when I zoom into the map -- the image should be bigger; when I zoom out of the map -- the image should be smaller.
Please advise.
Thanks and best regards,
Kae Woei
