Dear Gurus!
Unexpected problem.
For some operations I decide to show new tab with copy of the Map element from the current tab (in the tabControl).
<esri:Map x:Name="MyMap" Background="White" WrapAround="true"
Extent="3200000,8500000,4250000,10130000">
<esri:OpenStreetMapLayer ID="OSMLayer" Style="Mapnik" />
<esri:ArcGISDynamicMapServiceLayer ID="Карта РК"
Url="http://myServer:6080/ArcGIS/rest/services/karelia/MapServer" />
<esri:GraphicsLayer ID="MyGraphicsLayer" MouseLeftButtonDown="GraphicsLayer_MouseLeftButtonDown" />
</esri:Map>
And want to set centerPoint and resolution from the first tab. In the next event
<i:Interaction.Triggers>
<i:EventTrigger EventName="Loaded">
<i:InvokeCommandAction Command="{Binding SetMapRefCommand, Mode=OneWay}"
CommandParameter="{Binding ElementName=MyMap,Mode=OneWay}" />
</i:EventTrigger>
</i:Interaction.Triggers>as follows in the ViewModel for this control
public void SetMapRef(object item)
myMap = (Map)item;
MapModule.ViewModels.MapViewModel.centerAndZoom(myMap, currentCentrPointFromFirst, MapResolutionFromFirst);
}Where centerAndZoom procedure is
public static void centerAndZoom(ESRI.ArcGIS.Client.Map map, ESRI.ArcGIS.Client.Geometry.MapPoint mapPoint, double resolution)
double ratio = 1.0;
if (map.Resolution != 0.0)
ratio = resolution / map.Resolution;
if (ratio == 1.0)
map.PanTo(mapPoint);
else
ESRI.ArcGIS.Client.Geometry.MapPoint mapCenter = map.Extent.GetCenter();
double X = (mapPoint.X - ratio * mapCenter.X) / (1 - ratio);
double Y = (mapPoint.Y - ratio * mapCenter.Y) / (1 - ratio);
map.ZoomToResolution(resolution, new ESRI.ArcGIS.Client.Geometry.MapPoint(X, Y));
} But it does not work. When I do it from the click button Event - all works fine. I can't understand - what is the reason...
How to fix?
