I can't seem to get the placeholder text to work for the geocoder dijit. It isn't working in the sample http://developers.arcgis.com/en/javascript/samples/locator_suffix/ either. Any Ideas?My code matches the example.var geocoder = new esri.dijit.Geocoder({
autoComplete: true,
maxLocations: 10,
map: map,
arcgisGeocoder: {
placeholder:"Search Location..."
}, "location-search1");
geocoder.startup();The element that gets built is this...[HTML]<input id="location-search1_input" type="text" role="textbox" data-dojo-attach-event="ondijitclick:_inputClick" data-dojo-attach-point="inputNode" autocomplete="off" value="" placeholder="" tabindex="0" aria-haspopup="true">[/HTML]Im currently using JS to set it after the fact but would prefer to just use the dijit's capabilities.$("#location-search1_input").attr("placeholder","Location Search..")Thanks,Tony
