Hi all,
I am having a problem because I cannot use the same layer for popup and visibility. What I want is when a layer is off, this layer has not popup window till is in on again. But if I put the same layer for both an error emerges like layer is not a function.
Here goes the code, TAKE INTO ACCOUNT THAT layerA = layerB. Thanks in advance:
<script src="http://js.arcgis.com/3.13/"></script>
<script>
var map, identifyTask, findTask, findParams, identifyParams;
require([
"esri/map",
"esri/geometry/Extent",
"esri/layers/FeatureLayer",
"esri/dijit/Legend",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/ImageParameters",
"esri/InfoTemplate",
"esri/dijit/BasemapGallery",
"esri/dijit/Scalebar",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleMarkerSymbol",
"esri/tasks/IdentifyTask",
"esri/tasks/IdentifyParameters",
"esri/tasks/FindParameters",
"esri/dijit/Popup",
"esri/dijit/Measurement",
"esri/toolbars/draw",
"esri/graphic",
"dojo/on",
"esri/tasks/query",
"esri/layers/LayerDrawingOptions",
"dojo/_base/Color",
"dojo/dom-construct",
"dojo/dom",
"dojo/query",
"esri/tasks/FindTask",
"dojo/_base/array",
"dojo/_base/connect",
"dojox/grid/DataGrid",
"dojo/data/ItemFileReadStore",
"dojo/_base/array", "dojo/parser",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dijit/layout/AccordionContainer",
"dijit/form/ComboBox",
"dojo/domReady!"
], function(
Map,
Extent,
FeatureLayer,
Legend,
ArcGISDynamicMapServiceLayer,
ImageParameters,
InfoTemplate,
BasemapGallery,
Scalebar,
SimpleFillSymbol,
SimpleLineSymbol,
SimpleMarkerSymbol,
IdentifyTask,
IdentifyParameters,
FindParameters,
Popup,
Measurement,
Draw,
Graphic,
on,
Query,
LayerDrawingOptions,
Color,
domConstruct,
dom,
query,
FindTask,
arrayUtils,
connect,
DataGrid,
ItemFileReadStore,
arrayUtils,
parser
parser.parse();
var extentinitial= new Extent({
"xmin":5533768.561124517,
"ymin":2910407.85970325,
"xmax":5969153.874236671,
"ymax":3018948.4398681484,
"spatialReference":{"wkid":102100,"latestWkid":2932}
var popup = new Popup({
fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]))
}, domConstruct.create("div"));
map = new Map("map", {
basemap:"topo",
extent: extentinitial,
zoom: 9
var layerA = new ArcGISDynamicMapServiceLayer("http://xyz", {
var basemapGallery = new BasemapGallery({
showArcGISBasemaps: true,
map: map
}, "basemapGallery");
basemapGallery.startup();
basemapGallery.on("error", function(msg) {
console.log("basemap gallery error: ", msg);
//add the legend
var legend = new Legend({
map: map,
}, "legendDiv");
legend.refresh([{layer:layerA, title:'LEGEND'}]);
legend.startup();
map.addLayer(layerA);
var visibleLayerIds = []
on(dom.byId("layer0CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer1CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer2CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer3CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer4CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer5CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer6CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer7CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer8CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer9CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer10CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer11CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer12CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer13CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer14CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer15CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer16CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer17CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer18CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer19CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer20CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer21CheckBox"), "change", updateLayerVisibility);
function updateLayerVisibility () {
var inputs = query(".list_item");
var inputCount = inputs.length;
visibleLayerIds = [];
for (var i = 0; i < inputCount; i++) {
if (inputs.checked) {
visibleLayerIds.push(inputs.value);
if (visibleLayerIds.length === 0) {
visibleLayerIds.push(21);
layerA.setVisibleLayers(visibleLayerIds);
map.on("load", mapReady);
var imageParameters = new ImageParameters();
imageParameters.layerIds = [0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21];
imageParameters.layerOption = ImageParameters.LAYER_OPTION_SHOW;
var layerB = "http://xyz";
map.addLayer(new ArcGISDynamicMapServiceLayer(layerB,
{"imageParameters": imageParameters, visible: false }));
function mapReady () {
mapClick = map.on("click", function(event){
executeIdentifyTask(event);
identifyTask = new IdentifyTask(layerB);
identifyParams = new IdentifyParameters();
identifyParams.tolerance = 3;
identifyParams.returnGeometry = true;
identifyParams.layerIds = [0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21];
identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_VISIBLE;
identifyParams.width = map.width;
identifyParams.height = map.height;
function executeIdentifyTask (event) {
identifyParams.geometry = event.mapPoint;
identifyParams.mapExtent = map.extent;
var deferred = identifyTask
.execute(identifyParams)
.addCallback(function (response) {
return arrayUtils.map(response, function (result) {
var feature = result.feature;
var layerName = result.layerName;
feature.attributes.layerName = layerB;
if (layerName === 'L1') {
var azTemplate = new InfoTemplate("L1");
feature.setInfoTemplate(azTemplate);
else if (layerName === 'L2') {
var hyTemplate = new InfoTemplate(
"L2");
feature.setInfoTemplate(hyTemplate);
else if (layerName === 'L3') {
var siTemplate = new InfoTemplate(
"L3");
feature.setInfoTemplate(siTemplate);
else if (layerName === 'L4') {
var psTemplate = new InfoTemplate(
"L4");
feature.setInfoTemplate(psTemplate);
else if (layerName === 'L5') {
var daTemplate = new InfoTemplate(
"L5");
feature.setInfoTemplate(daTemplate);
else if (layerName === 'L6') {
var slTemplate = new InfoTemplate(
"L6");
feature.setInfoTemplate(slTemplate);
else if (layerName === 'L7') {
var tsTemplate = new InfoTemplate(
"L7");
feature.setInfoTemplate(tsTemplate);
else if (layerName === 'L8') {
var acoTemplate = new InfoTemplate(
"L8");
feature.setInfoTemplate(acoTemplate);
else if (layerName === 'L9') {
var ceTemplate = new InfoTemplate(
"L9");
feature.setInfoTemplate(ceTemplate);
else if (layerName === 'L10') {
var vrsTemplate = new InfoTemplate(
"L10");
feature.setInfoTemplate(vrsTemplate);
else if (layerName === 'L11') {
var rsTemplate = new InfoTemplate(
"L11");
feature.setInfoTemplate(rsTemplate);
else if (layerName === 'L12') {
var cuTemplate = new InfoTemplate(
"L12");
feature.setInfoTemplate(cuTemplate);
else if (layerName === 'L13') {
var rmTemplate = new InfoTemplate(
"L13");
feature.setInfoTemplate(rmTemplate);
else if (layerName === 'L14') {
var shTemplate = new InfoTemplate(
"L14");
feature.setInfoTemplate(shTemplate);
else if (layerName === 'L15') {
var acTemplate = new InfoTemplate(
"L15");
feature.setInfoTemplate(acTemplate);
else if (layerName === 'L16') {
var foTemplate = new InfoTemplate(
"L16");
feature.setInfoTemplate(foTemplate);
else if (layerName === 'L17') {
var geTemplate = new InfoTemplate(
"L17");
feature.setInfoTemplate(geTemplate);
else if (layerName === 'L18') {
"L18");
else if (layerName === 'L19') {
var pvTemplate = new InfoTemplate(
"L19");
feature.setInfoTemplate(pvTemplate);
else if (layerName === 'L20') {
var lpTemplate = new InfoTemplate(
"L20");
feature.setInfoTemplate(lpTemplate);
else if (layerName === 'L21') {
"L21");
else if (layerName === 'L22') {
var bsTemplate = new InfoTemplate(
"L22");
feature.setInfoTemplate(bsTemplate);
return feature;
map.infoWindow.setFeatures([deferred]);
map.infoWindow.show(event.mapPoint);
var scalebar = new Scalebar({
map: map,
scalebarUnit: "metric"
function initt() {
esri.config.defaults.io.proxyUrl = "/proxy/";
esri.config.defaults.io.alwaysUseProxy = false;
esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
dojo.connect(map, 'onLoad', function(map) {
var measurement = new Measurement({
map: map
}, dom.byId("measurementDiv"));
measurement.startup();
on(measurement, "tool-change", function(){
mapClick.remove();
on(measurement, "measure-end", function(){
measurement.setTool("distance", false);
measurement.setTool("area", false);
measurement.setTool("location", false);
mapReady();
map.graphics.clear();
dojo.ready(initt);
</script>
