I noticed I had this "_WFL1" appended to the end of a feature service item name following publishing the service from Pro. I don't know where this came from or what it means/stands for? I did publish a web map in Pro with the same item name prior to the feature service being published. So I thought the append was to due to the web map and service having the same item name?
Whenever you publish something to a Portal, unique naming is enforced and aided by the publishing process by adding something like this. In your case this is a WebFeatureLayer ... and a definition to it will be published as a document, too
Thank you, I had a hunch this was the case.
Is there a way to prevent this? Or remove it afterward? Its aesthetically displeasing seeing this in the title of feature layers when I pull them into pro, and how it remains in hosted links after changing the layer name.
