Hello everyone,
I am wondering why this code is not showing any graphic in a map.
I have the following:
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/Extent"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/graphicsUtils"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/query"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/QueryTask"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/dom"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/parser"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/ready"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/on"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/layout/ContentPane"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/layout/BorderContainer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/kernel"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'esri/graphic'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'esri/layers/GraphicsLayer'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleMarkerSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleLineSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/Color"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>
FeatureLayer<SPAN class="punctuation token">,</SPAN> Extent<SPAN class="punctuation token">,</SPAN> graphicsUtils<SPAN class="punctuation token">,</SPAN> Query<SPAN class="punctuation token">,</SPAN> QueryTask<SPAN class="punctuation token">,</SPAN> Map<SPAN class="punctuation token">,</SPAN>
dom<SPAN class="punctuation token">,</SPAN> parser<SPAN class="punctuation token">,</SPAN> ready<SPAN class="punctuation token">,</SPAN> on<SPAN class="punctuation token">,</SPAN> ContentPane<SPAN class="punctuation token">,</SPAN> BorderContainer<SPAN class="punctuation token">,</SPAN> kernel<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> GraphicsLayer<SPAN class="punctuation token">,</SPAN> SimpleMarkerSymbol<SPAN class="punctuation token">,</SPAN> Color<SPAN class="punctuation token">,</SPAN> SimpleLineSymbol
<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
parser<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">ready</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"topo"</SPAN><SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">71.7018</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">33.0228</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN><SPAN class="number token">8</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Load a FeatureTable to the application once map loads</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"load"</SPAN><SPAN class="punctuation token">,</SPAN> loadData<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">loadData</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> l <SPAN class="operator token">=</SPAN> <SPAN class="token function">login</SPAN><SPAN class="punctuation token">(</SPAN>kernel<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>resolve<SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>resolve<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> gLayerMedidor2 <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> r <SPAN class="operator token">=</SPAN> Math<SPAN class="punctuation token">.</SPAN><SPAN class="token function">floor</SPAN><SPAN class="punctuation token">(</SPAN>Math<SPAN class="punctuation token">.</SPAN><SPAN class="token function">random</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">*</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> g <SPAN class="operator token">=</SPAN> Math<SPAN class="punctuation token">.</SPAN><SPAN class="token function">floor</SPAN><SPAN class="punctuation token">(</SPAN>Math<SPAN class="punctuation token">.</SPAN><SPAN class="token function">random</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">*</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> b <SPAN class="operator token">=</SPAN> Math<SPAN class="punctuation token">.</SPAN><SPAN class="token function">floor</SPAN><SPAN class="punctuation token">(</SPAN>Math<SPAN class="punctuation token">.</SPAN><SPAN class="token function">random</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">*</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> mySymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleMarkerSymbol</SPAN><SPAN class="punctuation token">(</SPAN>
SimpleMarkerSymbol<SPAN class="punctuation token">.</SPAN>STYLE_CIRCLE<SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">20</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>
SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>r<SPAN class="punctuation token">,</SPAN> g<SPAN class="punctuation token">,</SPAN> b<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.5</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">10</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>r<SPAN class="punctuation token">,</SPAN> g<SPAN class="punctuation token">,</SPAN> b<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.9</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> p <SPAN class="operator token">=</SPAN> <SPAN class="token function">loadPostes</SPAN><SPAN class="punctuation token">(</SPAN>Query<SPAN class="punctuation token">,</SPAN>QueryTask<SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">,</SPAN> resolve<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"678742"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"678743"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>resolve<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"pipes"</SPAN><SPAN class="punctuation token">)</SPAN>
gLayerMedidor2<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN>resolve<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">,</SPAN>mySymbol<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>resolve<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// map.graphics.add(new Graphic(featureSet.features[0].geometry, mySymbol));</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>gLayerMedidor2<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">catch</SPAN><SPAN class="punctuation token">(</SPAN>error<SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>error<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"error postes"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">catch</SPAN><SPAN class="punctuation token">(</SPAN>reject<SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>reject<SPAN class="punctuation token">)</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Also in the loadPostes i have a promise that works like:
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">loadPostes</SPAN><SPAN class="punctuation token">(</SPAN>Query<SPAN class="punctuation token">,</SPAN> QueryTask<SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">,</SPAN> layers<SPAN class="punctuation token">,</SPAN> rotulos<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> entregas <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">let</SPAN> index <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> index <SPAN class="operator token"><</SPAN> rotulos<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> index<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="punctuation token">(</SPAN>index <SPAN class="operator token">==</SPAN> rotulos<SPAN class="punctuation token">.</SPAN>length<SPAN class="number token">-1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">?</SPAN> entregas <SPAN class="operator token">=</SPAN> entregas <SPAN class="operator token">+</SPAN> `rotulo <SPAN class="operator token">=</SPAN> <SPAN class="string token">'${rotulos[index]}'</SPAN><SPAN class="template-string token"><SPAN class="string token">` : entregas = entregas + `</SPAN></SPAN>rotulo <SPAN class="operator token">=</SPAN> <SPAN class="string token">'${rotulos[index]}'</SPAN> or `<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> promise <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Promise</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>resolve<SPAN class="punctuation token">,</SPAN>reject<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> qTaskInterruptions <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN>layers<SPAN class="punctuation token">.</SPAN>pole_layer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> qInterruptions <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
qInterruptions<SPAN class="punctuation token">.</SPAN>returnGeometry <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
qInterruptions<SPAN class="punctuation token">.</SPAN>outFields<SPAN class="operator token">=</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
qInterruptions<SPAN class="punctuation token">.</SPAN>where <SPAN class="operator token">=</SPAN> entregas<SPAN class="punctuation token">;</SPAN>
qTaskInterruptions<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>qInterruptions<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN>featureSet<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>featureSet<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">reject</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">resolve</SPAN><SPAN class="punctuation token">(</SPAN>featureSet<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN>Errorq<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>Errorq<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"Error doing query for rotulos"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> promise<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>The promise is actualyl working fine cuz i have the result in console but it just not adding the graphics into the map to see them.
What am i doing wrong?
Thanks in advice!
