<SPAN class="keyword token">import</SPAN> arcpy
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>overwriteOutput <SPAN class="operator token">=</SPAN> <SPAN class="number token">1</SPAN>
<SPAN class="comment token"># in path to raw line data</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"S:\General-Offices-GO-Trans\SLR-Mapping\GIS_Projects_2018\Smart_T_Line_Model\geodata\TEST_LINES.gdb"</SPAN>
<SPAN class="comment token"># out path to buffered lines</SPAN>
outbufferpath <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"S:\General-Offices-GO-Trans\SLR-Mapping\GIS_Projects_2018\Smart_T_Line_Model\geodata\TEST_BUFFER.gdb"</SPAN>
<SPAN class="comment token"># BUFFER LINE FEATURES FROM RAW LINE DATA FOLDER TEST_LINES.GDB"</SPAN>
featureClassList <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFeatureClasses<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> featureClass <SPAN class="keyword token">in</SPAN> featureClassList<SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Buffer_analysis<SPAN class="punctuation token">(</SPAN>featureClass<SPAN class="punctuation token">,</SPAN> outbufferpath<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"1250 Feet"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"FULL"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ROUND"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NONE"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
There is an error somewhere in the arcpy.Buffer_analysis line of code. Can anyone assist?
Thanks!
Here is what is returned after arcpy command:
arcpy.analysis.Buffer(featureClass, outbufferpath + featureClass, "1250 Feet", "FULL", "ROUND", "NONE")
File "<string>", line 1, in <module>
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\analysis.py", line 1098, in Buffer
raise e
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\analysis.py", line 1095, in Buffer
retval = convertArcObjectToPythonObject(gp.Buffer_analysis(*gp_fixargs((in_features, out_feature_class, buffer_distance_or_field, line_side, line_end_type, dissolve_option, dissolve_field, method), True)))
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 496, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 000229: Cannot open T_0517__BRI_DJS_TP_34_5_1Failed to execute (Buffer).
