i get flex viewer2.5 source code, create a flex Library project named "xyz" in flashBuilder4.6, copy the flex viewer3.0 source code files to the project "xyz", and add swc file refrence to "agslib-2.5-2011-11-30.swc', then building is ok, generate a file "xyz.swc". create a flex Application project named "MyApp", it add project refrence to "xyz", building is ok, but throw a exception while runing the "MyApp", the exception information is "null refrence ". excepiton locate Flex viewer2.5 source file "MapManager.mxml" . why "styleManager.getStyleDeclaration("com.esri.ags.components.supportClasses.InfoWindow")" return value is null???? protected override function partAdded(partName:String, instance:Object):void
super.partAdded(partName, instance);
if (instance === map)
var cssStyleDeclaration:CSSStyleDeclaration = styleManager.getStyleDeclaration("com.esri.ags.components.supportClasses.InfoWindow")
cssStyleDeclaration.setStyle("backgroundColor", getStyle('contentBackgroundColor'));
styleManager.setStyleDeclaration("com.esri.ags.components.supportClasses.InfoWindow", cssStyleDeclaration, true);
