FeatureForm does not show coded value domains descriptions when editable is set to false. See WorkType field name below.
<SPAN class="keyword token">const</SPAN> featureLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"https://ddotgis.dc.gov/arcgis/rest/services/Test/TestPoint/FeatureServer/0"</SPAN><SPAN class="punctuation token">,</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
formTemplate<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// Autocasts to new FormTemplate</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Test Point"</SPAN><SPAN class="punctuation token">,</SPAN>
description<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN>
elements<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// Autocasts to new GroupElement</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"group"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="comment token">// Autocasts to new FieldElement</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"field"</SPAN><SPAN class="punctuation token">,</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"BudgetYear"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Budget Year"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"WorkType"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Work Type"</SPAN><SPAN class="punctuation token">,</SPAN>
editable<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ProjectStatus"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Status"</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"PercentCompleted"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Percentage"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="comment token">// end of form template elements</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Test site: https://codepen.io/markoskifle/pen/OJXzeyq?editors=1000
