I'm building a small app that has a basemap and one featureLayer that has an infoWindow associated with it. When the user clicks on one of those features, I also need to retrieve the coordinates of the feature that the user clicked on. My understanding is that you can use the OnClick event with dojo.connect to do this: dojo.connect(map,"onClick",function(evt){ var query = new esri.tasks.Query(); query.geometry = pointToExtent(map,evt.mapPoint,10); var deferred = theFeatureLayer.selectFeatures(query,esri.layers.FeatureLayer.SELECTION_NEW); map.infoWindow.setFeatures([deferred]); map.infoWindow.show(evt.mapPoint); alert('Made it here!'); var pt = new esri.geometry.Point(evt.mapPoint.y,evt.mapPoint.x, new esri.SpatialReference({wkid:3857})); var MercPt = esri.geometry.webMercatorToGeographic(evt.mapPoint); var theLong = MercPt.x; var theLat = MercPt.y; var didSucceed = window.clipboardData.setData('Text', '@Coord:' + theLong.toString() + ',' + theLat.toString() ); });If a user clicks on the map where there isn't a feature, the OnClick event captures it and I'm able to access the click point's coordinates. If they click on a feature, it seems to bypass the OnClick code (hence my small alert line in the code above). What's the best way to capture the coordinates of a clicked feature??Thanks!Steve
