I'm developing with JS 2D API 3.24 in WAB 2.8, in the framework of AGS 10.6.1.
I need a map with the property wrapAround180 set to true. This is not a property configurable in WAB. I'm trying to configure it writting the property in config.json, in entry "map", sub entry "mapOptions", below "lods", with something like this:
"map": {
"3D": false,
"itemId": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
"mapOptions": {
"lods": [
"level": 13,
"scale": 1000,
"resolution": 0.00000237
"wrapAround180": true,
"extent": { ...
Nevertheless, when app is launched, the map has this property in false.
If in the same line of the config.json file I put the property "zoom": 4,deleting "wraparound180" property, then the map starts in zoom = 4. In others words: it must work.
The file config-readme.txt confirm that in "mapOptions" entry of config.json we can put same options as the map API options.
Debbuging, I can see that this property is true until _show2DWebMap method in MapManager.js file, in jimu.js folder of the App. In this method, map.wrapAround180 is false. I have chenged this value programatically and runs ok... until we do zoom, when map becomes invisible.
Some suggestion?
Thanks in advance.
