I have published a map in ArcGIS Server with Feature Access enabled and I can see in the REST Directory the 2 services that where created (MapServer and FeatureServer).
I can also edit the map with a web application created with ArcgiS JS API. Everything works fine and the changes in map are saved in a postgresql database where the data of the layers are.
I would like to edit the map with ArcMap, but my problem is that I cannot see the Feature Service in the AcrCatalog. Only the Map Service is visible. That means I cannot create a local copy for editing.
Any Ideas?
Thank you
