I was wondering how to get the path of the add-in which I currently use. There are a lot of users (about 100), and they use different versions of our program from network. If believe it works as follows:
When the ArcMap starts, it loads for itself the dll-s from the proper path, which we gave in the Add-In window. When we wanted to see the proper path of the add-in, we used <SPAN class="typ">Assembly</SPAN><SPAN class="pun">.</SPAN><SPAN class="typ">GetExecutingAssembly</SPAN><SPAN class="pun">().</SPAN><SPAN class="typ">Location in c#</SPAN><SPAN class="pun"></SPAN>, and it gave back the assambly-cache folder used by ArcGIS 10.0.
We want to know the given path of the toolbar which I developed.
We use multiple add-ins, therefore the AddInFoldersList.xml is not satisfactory, which is stored in user/.../AppData/Roaming/ESRI//Desktop10.0
