I can add a wms layer to a custom web map, however is it possible to change the WMS layer properties dynamically?
For instance I'd like to pass a value from a text textbox to the the wms layer property so the users can adjust the wms layer properties. Ex. TIME or transparency percentage, etc.
See customLayerParameters: {'TIME': datePick.value}
Trying to build an app which displays Nexrad radar reflectivity over time.
Thanks.
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
ArcGIS API for JavaScript, https://js.arcgis.com
For more information about the layers-wms sample,
read the original sample description at developers.arcgis.com.
https://developers.arcgis.com/javascript/latest/sample-code/layers-wms/index.html
<title>WMSLayer - 4.15</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
#titleDiv {
padding: 10px;
font-weight: 36;
text-align: center;
</style>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.13/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.13/"></script>
<script>
var radtime;
require([
"esri/Map",
"esri/layers/MapImageLayer",
"esri/views/MapView",
"esri/layers/WMSLayer",
"esri/Basemap",
"esri/core/watchUtils"
], function(Map, MapImageLayer, MapView, WMSLayer, Basemap, watchUtils) {
let wmsLayer = new WMSLayer({
title: "WMS Layer",
url: "https://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r-t.cgi?",
sublayers: [
//customLayerParameters: {'TIME': '2020-06-29T23:45'}
var map = new Map({
basemap: "streets",
layers: [wmsLayer]
var view = new MapView({
map: map,
// zoom: initZoom,
// center: initPosition
container: "viewDiv",
zoom: 3,
center: [-98, 37]
// add the UI for titles, stats and chart.
view.ui.add("titleDiv", "top-right");
function myFunction() {
window.radtime = document.getElementById("datePick").value;
console.log(radtime)
var el = document.getElementById("execute");
if (el.addEventListener)
el.addEventListener("click", myFunction, false);
else if (el.attachEvent)
el.attachEvent('onclick', myFunction);
</script>
</head>
<body>
<select name="datePick" id="datePick">
<option value="2020-04-01T00:00">2020-04-01T00:00</option>
<option value="2020-05-01T00:00">2020-05-01T00:00</option>
<option value="2020-06-01T00:00">2020-06-01T00:00</option>
</select>
<input name="textbox1" id="textbox1" type="dropdown" value="2020-06-01T00:00"/>
<input id="execute" input name="buttonExecute" onclick="myFunction();" type="button" value="Execute" />
<div id="viewDiv">
<div id="titleDiv" type=textbox value=test>title</div>
</div>
</body>
</html>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
