TypeError: Error #1006: value is not a function. at com.esri.viewer.managers::MapManager/drawEndHandler() at flash.events::EventDispatcher/dispatchEventFunction() at flash.events::EventDispatcher/dispatchEvent() at com.esri.ags.tools::DrawTool/map_clickFirstHandler() at flash.events::EventDispatcher/dispatchEventFunction() at flash.events::EventDispatcher/dispatchEvent() at mx.core::UIComponent/dispatchEvent() at com.esri.ags.layers.supportClasses::LayerContainer/dispatchMapMouseEvent() at com.esri.ags.layers.supportClasses::LayerContainer/mouseUpHandler()
There seems to be an issue with the Flex API draw tool (or I'm doing something wrong). If you use this sample:http://resources.arcgis.com/en/help/flex-api/samples/index.html#/Use_the_DrawTool/01nq00000065000000/And use MULTIPOINT instead of point, it doesn't work the way it should. It just keeps adding new points. If you switch back to the Flex API 3.0 library it works correctly and adds points each time you click, just doesn't work correctly with Flex API 3.3 library?
