Currently i am attempting to publish a Tile layer from a hosted feature Service (Note all services are hosted in AGOL). Yet when attempts are made to generate tiles automatically i find the option to be grayed out completely and only.
The layer i am attempting to use is a freshly minted Feature Service from a Geodatabase. Nothing seems out of the ordinary.
A second layer which I've published else where does allow the generation of tiles automatically. There is no rime or reason as to why it would be grayed out.
According to the Help document and the blog post this should be a straight forward endeavor.
https://community.esri.com/community/gis/web-gis/arcgisonline/blog/2017/07/06/arcgis-blog-publishing-tiles-from-features-efficient-automatic-and-economical
The layer I am publishing is simply a POINT Feature class, and the example one which does have dynamic tiling enable is a similar data set. Unless it needs to be published from a hosted view. But I've tried a variety of different formats.
The difference between the two layers would be that one (That is grayed out) was published right from ArcMap 10.6 while the other was a layer generated by Survey123 as a feature service. Unless there some behind the scenes bs happening that defines these two layers differently I am at a loss. As the "Create Tile Automatically" button which should be visible when you
CLICK FEATUER SERVICE DESCRIPTION > PUBLISH > TILE
Does not even appear. Will try to publish the data from a uploaded zip geodatabase.
Has anyone else encountered this? I Believe the March/April AGOL updates may have done something wiggy to things.
Is there perhaps some other hidden requirements to have it enabled?
