I am trying to add analysis widget but getting the error "Your user role cannot perform analysis. In order to perform analysis, the administrator of your organization needs to grant you certain privileges."
I am the administrator and I have all permission in my portal.
I set up the ArcGIS enterprise 10.5 (ArcGIS Server + Portal). I have federated the ArcGIS server with portal.
I configured the utility services from my ArcGIS server.I set the hosted server to act as your portal's hosting server in portal's Server tab setting. I checked Spatial Analysis GP service is running.
I have not installed & configured ArcGIS Data Store. If I am trying to add analysis widget I am getting above error.
Now, I want to install and configure the ArcGIS data Store :
Do I need to unfederate the ArcGIS server and start install data store and configure? What happen if I unfederate the ArcGIS server ?
What if without unfederate ArcGIS server, start install and configure the data store ?
Is it mandatory to unfederate the ArcGIS server in order to configure datastore and to use Analysis widget ?
What is the right process ?
I really appreciate the help
on this.
Many thanks,
