Line Code 68 <esri:SimpleFillSymbol id="mouseOverSymbol" alpha="0.5"> 69 <esri:SimpleLineSymbol width="0" color="0xFF0000"/> 70 </esri:SimpleFillSymbol> 71 <esri:SimpleFillSymbol id="defaultsym" alpha="0.2"> 72 <esri:SimpleLineSymbol width="1" color="0xEEEEEE"/> 73 </esri:SimpleFillSymbol>
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="CBWS-test"> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.SpatialReference; import com.esri.ags.events.GraphicEvent; import com.esri.ags.geometry.Extent; protected function countyData_graphicAddHandler(event:GraphicEvent):void { event.graphic.addEventListener(MouseEvent.MOUSE_OVER, onMouseOverHandler); event.graphic.addEventListener(MouseEvent.MOUSE_OUT, onMouseOutHandler); } private function onMouseOverHandler(event:MouseEvent):void { var gr:Graphic = Graphic(event.target); gr.symbol = mouseOverSymbol; myTextArea.htmlText = "<b> FIPS: </b>" + gr.attributes['ba_cb_cty.FPS'] + "\n" + "<b>County Name: </b>" + gr.attributes['ba_cb_cty.Name'] + "\n"; myMap.infoWindow.label = gr.attributes.NAME; myMap.infoWindow.closeButtonVisible = false; myMap.infoWindow.show(myMap.toMapFromStage(event.stageX, event.stageY)); } private function onMouseOutHandler(event:MouseEvent):void { var gr:Graphic = Graphic(event.target); gr.symbol = defaultsym; myMap.infoWindow.hide(); } private function zoomCBWS():void { var CBWSExtent:Extent = new Extent(-8200000, 4450000, -8000000, 5200000, new SpatialReference(102100)); myMap.extent = CBWSExtent; // make sure the whole extent is visible if (!myMap.extent.contains(CBWSExtent)) { myMap.level--; } } ]]> </fx:Script> <fx:Style> @namespace esri "http://www.esri.com/2008/ags"; esri|InfoWindow { content-background-alpha : 0; background-color : yellow; background-alpha : 0.8; border-style : solid; } </fx:Style> <fx:Declarations> <esri:SimpleFillSymbol id="mouseOverSymbol" alpha="0.5"> <esri:SimpleLineSymbol width="0" color="0xFF0000"/> </esri:SimpleFillSymbol> <esri:SimpleFillSymbol id="defaultsym" alpha="0.2"> <esri:SimpleLineSymbol width="1" color="0xEEEEEE"/> </esri:SimpleFillSymbol> </fx:Declarations> <s:layout> <s:VerticalLayout/> </s:layout> <esri:Map id="myMap" load="zoomCBWS()"> <esri:infoWindowContent> <mx:TextArea id="myTextArea" width="250" height="95"/> </esri:infoWindowContent> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> <esri:FeatureLayer id="countyData" useAMF="true" mode="onDemand" graphicAdd="countyData_graphicAddHandler(event)" url="http://204.236.161.112/ArcGIS/rest/services/CountyCombined-added/MapServer/4" alpha=".8" outFields=" "/> </esri:Map> <s:Label width="100%" text="Need to find and insert 'code' for name of layer loaded."/> </s:Application>
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="CBWS-test"> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.SpatialReference; import com.esri.ags.events.GraphicEvent; import com.esri.ags.geometry.Extent; protected function countyData_graphicAddHandler(event:GraphicEvent):void { event.graphic.addEventListener(MouseEvent.MOUSE_OVER, onMouseOverHandler); event.graphic.addEventListener(MouseEvent.MOUSE_OUT, onMouseOutHandler); } private function onMouseOverHandler(event:MouseEvent):void { var gr:Graphic = Graphic(event.target); gr.symbol = mouseOverSymbol; myTextArea.htmlText = "<b> FIPS: </b>" + gr.attributes.ba_cb_cty.FPS.toString() + "\n" + "<b>County Name: </b>" + gr.attributes.NAME.toString() + "\n" + "<b>Males: </b>" + gr.attributes.MALES + "\n" + "<b>2007 Females: </b>" + gr.attributes.FEMALES + "\n" + "<b>Total Population in 2007: </b>" + gr.attributes.POP2007; myMap.infoWindow.label = gr.attributes.NAME; myMap.infoWindow.closeButtonVisible = false; myMap.infoWindow.show(myMap.toMapFromStage(event.stageX, event.stageY)); } private function onMouseOutHandler(event:MouseEvent):void { var gr:Graphic = Graphic(event.target); gr.symbol = defaultsym; myMap.infoWindow.hide(); } private function zoomCBWS():void { var CBWSExtent:Extent = new Extent(-8200000, 4450000, -8000000, 5200000, new SpatialReference(102100)); myMap.extent = CBWSExtent; // make sure the whole extent is visible if (!myMap.extent.contains(CBWSExtent)) { myMap.level--; } } ]]> </fx:Script> <fx:Style> @namespace esri "http://www.esri.com/2008/ags"; esri|InfoWindow { content-background-alpha : 0; background-color : yellow; background-alpha : 0.8; border-style : solid; } </fx:Style> <fx:Declarations> <esri:SimpleFillSymbol id="mouseOverSymbol" alpha="0.5"> <esri:SimpleLineSymbol width="0" color="0xFF0000"/> </esri:SimpleFillSymbol> <esri:SimpleFillSymbol id="defaultsym" alpha="0.2"> <esri:SimpleLineSymbol width="1" color="0xEEEEEE"/> </esri:SimpleFillSymbol> </fx:Declarations> <s:layout> <s:VerticalLayout/> </s:layout> <esri:Map id="myMap" load="zoomCBWS()"> <esri:infoWindowContent> <mx:TextArea id="myTextArea" width="250" height="95"/> </esri:infoWindowContent> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> <esri:FeatureLayer id="countyData" url="http://204.236.161.112/ArcGIS/rest/services/CountyCombined-added/MapServer/4" alpha=".8"/> </esri:Map> <s:Label width="100%" text="Need to find and insert 'code' for name of layer loaded."/> </s:Application>
